Home > Technical > Manifold leakage |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 |
Wed Feb 21 2024 10:06pm |
Thu Feb 22 2024 9:37am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 431 |
Probably fuel feed line is loose or fuel return o ring is damaged. Injector seat would be more carbon. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Feb 22 2024 12:45pm |
There is plenty of carbon about, maybe not seeing it against the black cover . One of the above pics show a white hue being emitted . This is part of the video I was trying to send you . |
Thu Feb 22 2024 1:43pm |
On further inspection , the manifoldsurrounding the injector or injectors is caked hard with treacle , so definitely fuel and combustion.
Thu Feb 22 2024 8:48pm |
Need some help here , a bit embarrassing ! I blocked the inlet tubes to prevent ingress of muck . Forgot about them and now one of them has a towel sucked in to inlet and so where do the pipes end up do they go to the intercollegiate before the turbo , can’t see anything for everything else. |
Sat Feb 24 2024 5:32pm |
Is anyone good at showing a schematic of air take system from MAF to intake pipes on 3.6 V8, so that I can ascertain where to look first. It’s a nightmare from the top or bottom , but I do see some pipes. |
Sat Feb 24 2024 10:30pm |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 39 |
Sun Feb 25 2024 1:08am |
Thanks for that , looks right , as in 8 connected to turbo , which is one long pipe!
Mon Feb 26 2024 9:00pm |
