Home > Technical > Manifold leakage
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Manifold leakage
I have an obvious leal of fumes making their way into the interior . Stripped out the right cyl. head area thinking after a 2yr break and changing the inlet manifold cover , I instantly thought it was a cracked manifold again , but after stripping back the steel cover plate , it looks like one or two injectors are lealing around the base . I can only assume at this stage that the copper seals have gone , is it a case of replacing these or do I need a complete anchoring kit . It’s maybe an o ring on the cap , but it’s too close to the base to eliminate , so I think it’s leaking from there . I will try and show a video.
[img]Sorry this a photo , can’t load and struggling to load video !
Why can’t I load a video to this site. I am using google .
Post #639860 Wed Feb 21 2024 10:06pm
Pistnbroke
Exhaust fumes ? Diesel fumes?
You just have the video in your files and move it in the same way as a photo attachment. Always listen to old people or when they die you will live on in ignorance.
Post #639871 Thu Feb 22 2024 9:30am
alfapat
Fuel , come to think of it it’s probably both from the injector seat .
When I choose photos it doesn’t show videos to load.
Post #639872 Thu Feb 22 2024 9:37am
NoExpert
Probably fuel feed line is loose or fuel return o ring is damaged. Injector seat would be more carbon. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639880 Thu Feb 22 2024 12:45pm
alfapat
There is plenty of carbon about, maybe not seeing it against the black cover . One of the above pics show a white hue being emitted . This is part of the video I was trying to send you .
Post #639881 Thu Feb 22 2024 1:43pm
alfapat
On further inspection , the manifoldsurrounding the injector or injectors is caked hard with treacle , so definitely fuel and combustion.
Attempting to remove two injectors and copper seals arrive tomorrow . A MESS !
I chipped or tapped the particles onto the cloth , so being baked for a while !
Post #639897 Thu Feb 22 2024 8:48pm
alfapat
Need some help here , a bit embarrassing ! I blocked the inlet tubes to prevent ingress of muck . Forgot about them and now one of them has a towel sucked in to inlet and so where do the pipes end up do they go to the intercollegiate before the turbo , can’t see anything for everything else.
Post #639957 Sat Feb 24 2024 5:32pm
alfapat
Is anyone good at showing a schematic of air take system from MAF to intake pipes on 3.6 V8, so that I can ascertain where to look first. It’s a nightmare from the top or bottom , but I do see some pipes.
Post #639964 Sat Feb 24 2024 10:30pm
peterjj
Australia
Not real clear but 12 connects to 8 . Right hand turbo not shown in diagram. Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #639965 Sun Feb 25 2024 1:08am
alfapat
Thanks for that , looks right , as in 8 connected to turbo , which is one long pipe!
So after a say and maybe two , I finally managed to find the cloth , Nightmare , if only the fan shroud came off , I wouldn’t have to take the whole of the front end off , if I had discovered a pipe holding on to the fan shroud below . Spent all day on the rebuild and still got stuff to do rectify .
Sorry not a good pic of Pipe connection to turbo , but luckily I didnt rev up and draw the cloth in too deep !
Post #640011 Mon Feb 26 2024 9:00pm
