Home > General (L461) > L461 - issue - fuel filler cover not flush fitting.
Page 3 of 5 <12345>
Phil B
I may be seeing things, but I'm pretty sure my filler flap alignment issue has got worse since I took delivery. The flap seems to have warped outwards at the top and bottom edges.
Also, I find it really odd that the electric charging flap is not lockable - I'm just waiting from some young srcote to stuff the charging point with chewing gum "for a laugh"........
Post #638530 Thu Jan 04 2024 9:25am
bimjim
I'm pretty sure mine have got worse too. When the car arrived last summer they both looked OK, but it's more noticeable on both sides now.
Post #638532 Thu Jan 04 2024 10:02am
rsr
mine's the same, noticeably worse in the last month or so
Post #638536 Thu Jan 04 2024 4:29pm
Autobiography
As I understand it, it depends when the car was built. The cap ‘sets’ in line with the season it was manufactured - warmer months will be fine in warmer months and colder in colder…
Laughable…what a stupid design flaw.
Post #638545 Fri Jan 05 2024 7:06am
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Not sure how that theory works as mine was built in Sept 24 (saw it at factory) and didn’t fit at the end of the production and still doesn’t!
The shape means the rear of the flap does not align flush to the mechanism hence outside shape is out from the body.
We have a new Evoque as well and the flap aligns perfectly inside and out.
Have a new one on order as did @Scrumps who is waiting for painting and fitting.
Post #638547 Fri Jan 05 2024 8:27am
scrumps
My car was built 10th Oct 23.
Here’s the original flap.
New flap is on fourth re-paint due to poor quality and then incorrect colour.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #638551 Fri Jan 05 2024 1:51pm
Skyline
Hi all - same here, mine has got worse - dealer has offered to swap with another new Carpartian car - lets see how the paint match will be - will keep you posted.
Prashan MY23, 3.0 P440e PHEV AB, Carparthian Grey, Deep Garnett interior
MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian
Post #638552 Fri Jan 05 2024 3:16pm
JDPRRSUK
This is how mine looks
Post #638556 Fri Jan 05 2024 6:41pm
Skyline
And here's mine after 1500 miles
Post #638573 Sat Jan 06 2024 1:00pm
JDPRRSUK
@Scrumps - any update yet on your saga with repainting and fitting new flap?
Mine goes in on 24th for recall for BISC and if the flaps are now in stock they will test fit a new one.
Post #638686 Wed Jan 10 2024 8:23pm
scrumps
Car in next week for a couple of issues and a re-try at flap painting & fitting!
Post #638745 Fri Jan 12 2024 9:30pm
rbt1974
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
just got my car back and both filler and EV doors have been adjusted (new spring).
The fix is not perfect (you can notice if you're looking for it) but much better
Post #638795 Sun Jan 14 2024 6:39pm
Skyline
I'm taking mine in for a swap with a new showroom car - lets see if the paint matches / issue resolved.
P MY23, 3.0 P440e PHEV AB, Carparthian Grey, Deep Garnett interior
Post #638897 Wed Jan 17 2024 4:22pm
Montycarlo
New to the forum.
2023 D300 Dynamic SE
Thought I’d add myself to this list.
On my third flap
1st protruded at back
2nd Warped within a few days and had a bit of missing lacquer the size of a thumb print visible at a distance - so much for quality control!
3rd Ok when first fitted but slightly protruding now. Will have to keep an eye on it.
Post #638903 Wed Jan 17 2024 10:06pm
Skyline
Re: And here's mine after 1500 miles
Skyline wrote:
Had mine replaced with another flap from a showroom car - fit near perfect and colour match fine too - lets see how long it lasts - the painted panel itself, slid off the mechanism which was deemed fine - so a quick job to swap over.
Post #639099 Wed Jan 24 2024 3:47pm
Page 3 of 5 <12345>
