Home > General > Inlet manifold yet again
Phil2k
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Since owning this car the inlet manifold has split 3 times, im starting to get sick of it. It's the right hand side one as your facing the car from the front every time. I've only had the car 23 months. I did get the car remapped and I'm wondering if that has anything to do with it. It was a celtic tuning remap.
Going to cost another 1k now to fix again
Post #624531 Sat May 28 2022 11:06am
Well more boost would strain it.
Or maybe use higher quality part?
Or don’t use full throttle
Post #624532 Sat May 28 2022 11:21am
Phil2k
Its a good garage that did the work and they did say they would use genuine as for rpm I was in cruise control doing 75ish on the motorway.
Post #624534 Sat May 28 2022 11:27am
Disco_Mikey
Celtic maps are known to be "not very good"
Remove the map and fit a genuine manifold
If you do want it mapped again afterwards, stick to a specialist tuner (Alive/BAS etc) Thumbs Up
Post #624535 Sat May 28 2022 2:00pm
Phil2k
I'm removing the map definitely. I only had it done to help towing the horse trailer, we no longer have horses so not thatch need for it.
Post #624537 Sat May 28 2022 9:08pm
Why did you need to map it to tow horses? My SDV6 pulls our horse trailer very nicely. 2012 SDV6 - it's missing a couple of cylinders
Post #624538 Sat May 28 2022 9:49pm
Phil2k
Just wanted more torque and a few more mpg, it went from 22 with the trailer on up to 26.5
Post #624539 Sat May 28 2022 10:11pm
Phil2k
Just heard from the garage and they said the egr is stuck and that's what's caused it, is this possible? I'm trying to figure out how that would work
Post #624558 Mon May 30 2022 4:46pm
DirtBuddha
England 2010 Range Rover Sport TDV8 HSE Galway Green
Was the EGR ‘soft deleted’ i.e. coded out of action by software as part of the map?
Post #624564 Mon May 30 2022 6:00pm
Hot exhaust gasses melt plastic manifold
If stuck open
Post #624575 Tue May 31 2022 7:07am
Phil2k
I'm not sure I will phone the garage this morning and ask them. But if it was coded out for the map, surely it would stay closed and not recirc the hot gasses. I couldn't see any evidence of melted plastic on the manifold but I guess if it got very hot a few times it could of become more brittle
Post #624576 Tue May 31 2022 7:23am
OvalAutos
Let's hope that whoever does the job doesn't have to replace it within 9mths.
This was one we did last year. First it split along the seam while the owner was driving down the motorway and went in to RP. He called the AA out and they insisted on doing a road side repair (at the services) using 2 part epoxy glue. That fix worked until it cracked across the top Shocked
We charged £650+vat for the original job and £0 to replace it. Joe
Post #624582 Tue May 31 2022 2:03pm
One of mine cracked a couple or three years ago. Got the RP warning if trying to drive too enthusiastically. Had both replaced - much of the labour is for stripping / replacing the stuff around the manifold so doing both worked out cheaper than doing one then the other 6 months later.
So far, so good. Now on 132k miles. 2012 SDV6 - it's missing a couple of cylinders
Post #624584 Tue May 31 2022 5:01pm
Phil2k
Car is ready,
Replaced the manifold yet again
Remapped back to standard
Replaced 1 x egr valve
£900 cash
Was expecting a much bigger bill
Post #624829 Thu Jun 16 2022 3:17pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Thumbs Up Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #624831 Thu Jun 16 2022 4:08pm
