![]() | Home > General > Inlet manifold yet again |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5121 ![]() ![]() ![]() |
Well more boost would strain it.
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 ![]() ![]() ![]() |
Its a good garage that did the work and they did say they would use genuine as for rpm I was in cruise control doing 75ish on the motorway. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4524 ![]() ![]() ![]() |
Celtic maps are known to be "not very good"
I'm removing the map definitely. I only had it done to help towing the horse trailer, we no longer have horses so not thatch need for it. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9136 ![]() ![]() ![]() |
Why did you need to map it to tow horses? My SDV6 pulls our horse trailer very nicely. 2012 SDV6 - it's missing a couple of cylinders
Just wanted more torque and a few more mpg, it went from 22 with the trailer on up to 26.5 |
Just heard from the garage and they said the egr is stuck and that's what's caused it, is this possible? I'm trying to figure out how that would work |
DirtBuddha Member Since: 12 Jan 2022 Location: West Sussex Posts: 32 ![]() ![]() ![]() |
Was the EGR ‘soft deleted’ i.e. coded out of action by software as part of the map? |
Hot exhaust gasses melt plastic manifold
I'm not sure I will phone the garage this morning and ask them. But if it was coded out for the map, surely it would stay closed and not recirc the hot gasses. I couldn't see any evidence of melted plastic on the manifold but I guess if it got very hot a few times it could of become more brittle |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
Let's hope that whoever does the job doesn't have to replace it within 9mths.
One of mine cracked a couple or three years ago. Got the RP warning if trying to drive too enthusiastically. Had both replaced - much of the labour is for stripping / replacing the stuff around the manifold so doing both worked out cheaper than doing one then the other 6 months later.
Car is ready,
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
