| RRSPORT.CO.UK | ||
|  | Home > Technical > Suspension fault |
| Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595    | I think they are related , I had similar issue recently and replaced the faulty ride height sensor and then cleared the codes , all sorted   | ||
|  Mon Jan 31 2022 9:21pm |
| Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163      | Thanks for the reply
|  Mon Jan 31 2022 9:23pm |
| Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595    | No it was all okay  | ||
|  Mon Jan 31 2022 11:36pm |
| Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163      | Thanks | ||
|  Tue Feb 01 2022 11:55am |
| Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163      | New developments
|  Tue Feb 01 2022 10:01pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | The first code U0421-68 is simply a code telling you to check the Air suspension Control Module for faults. The one you need to check is C1A06-78. Have you checked to see if the height sensor has not just become disconnected for some reason? as there does appear to be few mechanical reason for this code as well as electrical.
|  Tue Feb 01 2022 11:20pm |
| Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595    | All the same things we had , Sensor was back order with no date when we required one . rear offside
|  Tue Feb 01 2022 11:23pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | If you do go for e-bay just remember there are two different one's, one for cars with CVD and one without.
|  Wed Feb 02 2022 3:27am |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | Did you try recalibrating the suspension? The main fault is the one for the right rear sensor saying it may be bad or out of calibration. You can swap the sensors side to side which will put them in a new range (2010+). You will have to recalibrate the suspension, but if a sensor is having issues holding a measurement due to wear, this can often resolve it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Wed Feb 02 2022 4:15am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Hardly worth the effort of swapping, for 50 quid you could get a pattern part.
|  Wed Feb 02 2022 4:42am |
| Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163      | Thanks for all the replies The new sensor will hopefully be in stock today I’ll change it and let you know what the results are | ||
|  Wed Feb 02 2022 8:15am |
| Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163      | I changed both rear ride height sensors and problem sorted but what a job as the top bolt on both sensors were seized causing the captive nuts to rotate so had to cut them off 😫😫😫
|  Thu Feb 03 2022 9:42pm |
| Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595    | Great news  | ||
|  Fri Feb 04 2022 12:16am |
| Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 80      | Looks like I have a similar issue, code C1A06-1C, which is rear right height sensor.
|  Fri Jul 29 2022 12:31pm |
| Posting Rules
