![]() | Home > Technical > Suspension fault |
| Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595
I think they are related , I had similar issue recently and replaced the faulty ride height sensor and then cleared the codes , all sorted |
| Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163
Thanks for the reply
No it was all okay |
Thanks |
New developments
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
The first code U0421-68 is simply a code telling you to check the Air suspension Control Module for faults. The one you need to check is C1A06-78. Have you checked to see if the height sensor has not just become disconnected for some reason? as there does appear to be few mechanical reason for this code as well as electrical.
All the same things we had , Sensor was back order with no date when we required one . rear offside
If you do go for e-bay just remember there are two different one's, one for cars with CVD and one without.
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 524
Did you try recalibrating the suspension? The main fault is the one for the right rear sensor saying it may be bad or out of calibration. You can swap the sensors side to side which will put them in a new range (2010+). You will have to recalibrate the suspension, but if a sensor is having issues holding a measurement due to wear, this can often resolve it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Hardly worth the effort of swapping, for 50 quid you could get a pattern part.
Thanks for all the replies The new sensor will hopefully be in stock today I’ll change it and let you know what the results are |
I changed both rear ride height sensors and problem sorted but what a job as the top bolt on both sensors were seized causing the captive nuts to rotate so had to cut them off 😫😫😫
Great news |
| Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 80
Looks like I have a similar issue, code C1A06-1C, which is rear right height sensor.
| All times are GMT |
