Home > Maintenance & Modifications > What should I get sorted first when purchasing second hand
Josh95
Northern Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
My RRS has 104,000 miles on the clock. The dealer I got it from gave it a full service in November with a local specialist.
It's MOT is due at the end of March. I've booked it in for the beginning of March to get it's transmission serviced and to look at a creaking noise it keeps making whenever I make tight turns, along with an MOT check.
Is there anything else I need to be getting sorted/ should be prioritising, giving that the car is 10 years old? It has a full Land Rover service history, but I can't find any receipts to say if any other specific work was carried out, aside from a full service.
Post #620929 Fri Jan 14 2022 12:19am
DrRob
Change all the transmission oils and not just the gearbox. Transfer and both diffs.
Also do the PAS fluid * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #620935 Fri Jan 14 2022 8:56am
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Creaking noise - suspension bushes.
New upper/lower front (and rear) suspension arms
If your steering is "lumpy" then a new lower steering column would be good.
4 wheel alignment is a good idea. Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Sadly gone - 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #620940 Fri Jan 14 2022 12:49pm
Stevepd
Be mindful of a cambelt/oil pump change. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #620942 Fri Jan 14 2022 3:08pm
