Home > Maintenance & Modifications > Bank B sequencer chain snapped
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Hi couple questions. Chain snapped,. Ive pulled the rocker off and fished the chain out but i cant find the link that would have snapped. Will it be an issue?
Also whats the chances of the valves being ok? Looking don the ports, the inlets all appear to be closed.
Post #619565 Sat Nov 27 2021 6:23pm
I guess you can live with a missing link.
Some people have gotten away with it. (Had sealed valves I mean)
Sometimes the cam lifters/rockers break which is good. Check they are in one piece.
Upto you whether you put it back together and hope for the best. (I would, and taking the head off the passenger side is hard work)
Look out for balance codes when it’s running again
And expect lots of smoke for a while, until Unburnt fuel clears
Post #619566 Sat Nov 27 2021 7:31pm
looneyfitter
Hi Andy, managed to get her all back up and running today she started within 20 seconds, but is running rough. Almost as if only running on 5 cylinders. Ive pulled injector connector off bank B one at a time and no noticable difference to engine note/tone.
No fault codes either. I can hear what sound like air being sucked in/escaping ans a tinking kind of noise which is strange.
All rocker arms and lifters were fine.
Im going to plug ids in tomorrow to see what I can find. Do you know where the balance section is on IDS?
Is there an easier way to get TDC other than removing the starter?
Also going to do a compression test. What should i be looking for?
Post #619751 Sat Dec 04 2021 8:58pm
You aren’t meant to pull inj. Connectors off these while running. They can jam open.
The compression results should be obvious.
Maybe air is being pushed back into the inlet during compression
Don’t know about ids
Post #619753 Sat Dec 04 2021 9:19pm
looneyfitter
Ah ok thanks mate. I didnt know that.
Im hoping i can get the glow plugs out easy without them sticking.
Beginning to think a valve is bent like you say as that could explain the tinking noise too?
Will report back. Cheers.
Post #619756 Sat Dec 04 2021 9:49pm
Gp access is poor passenger side.
Can’t you put the tester in the injector holes?
Post #619758 Sat Dec 04 2021 10:02pm
looneyfitter
Hi Andy, not really had any time to look at this. But just before i do. Could the alternator not working possibly have anything to do with mis fire? Lack power? Ie the ecu is limiting it? Has a fully charged battery and starts on the nose.
Also where is the starter relay? I need to imstall a switch under the bonnet so that i can turn the engine over when. On my own.
Cheers Gareth
Post #619927 Sun Dec 12 2021 3:52pm
Given what’s happened, it’s likely a bent valve
Starter relay is in the box next to the battery, marked SM
Post #619928 Sun Dec 12 2021 4:14pm
looneyfitter
Thanks Andy. Really didnt want to hear that mate. Is the exhaust manifold as difficult to remove as i think? 😫
Post #619939 Sun Dec 12 2021 8:06pm
The exhaust isn’t too much of an issue.
You remove the heat shields in the wheel arch, carefully marking, photoing, numbering how they fit, as they are a pain to refit.
Then using several long extensions, unbolt the EGRs, shield and then manifold
The manifold can stay where it is, and the head lifted slightly and moved into the center of the engine.
The fuel belt , and belt cover is far more of a hassle though
Post #619941 Sun Dec 12 2021 9:13pm
looneyfitter
Thanks andy will comp test and update. If comp is low, is it new head time or replace valves?
Mine an early engine so the fuel pump is fairly easy.
Post #619943 Sun Dec 12 2021 10:27pm
Get a used head off eBay.
Post #619944 Sun Dec 12 2021 10:39pm
looneyfitter
Hi mate, purchaced a head but didnt realise it doesnt come with cams or cam retainers. Can i just swap them over from my head?
Also are the injectors coded?? Cheers.
Post #619968 Tue Dec 14 2021 12:57am
You really need the cam retainers
But i don’t know what you have to loose, reuseing old ones.
Injectors aren’t coded
Jaguar 2.7 heads are the same
Post #619971 Tue Dec 14 2021 8:12am
looneyfitter
Thanks Andy. Looks like i need to take the plunge.
Post #619981 Tue Dec 14 2021 10:48pm
