Home > Technical > Heated seat hot spot |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
They do eventually fail by burning out. I had similar on my old TDV8. Simple enough job to fit a new heating element pad.
Thu Nov 25 2021 10:04pm |
Weston18 Member Since: 02 Oct 2021 Location: Northamptonshire Posts: 4 |
I will add it to the list of jobs thats slowly growing. Does it take long to strip the base down to replace? Not sure if its worth the hassle or keep an eye out for a replacement seat. |
Fri Nov 26 2021 12:04am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
Good opportunity to renew the foam seat pad at the same time as they do tend to collapse over time and age with sliding in and out.
Fri Nov 26 2021 12:33am |
See for yourself:
Fri Nov 26 2021 12:34am |
Spot on, thanks for finding that. I’ll get it done. Rear hub top bush today…….slowly working through the list. |
Fri Nov 26 2021 1:12pm |
