| RRSPORT.CO.UK | ||
|  | Home > General > Centre console fridge - always leave on? |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Only when using it, in my case. Can't see the point of using fuel to cool an empty box for no purpose. 2012 SDV6 - it's missing a couple of cylinders
|  Tue Jul 20 2021 9:29pm |
| Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43      | I thought that might be the case. Fridges are fairly power hungry appliances. | ||
|  Tue Jul 20 2021 9:48pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | It's not really a fridge as such, just a Peltier cooling device and an uninsulated box. 2012 SDV6 - it's missing a couple of cylinders
|  Tue Jul 20 2021 10:50pm |
| insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533      | I leave mine off all the time and find the cans left almost permanently inside (until drank) stay much cooler than if in the cabin on a hot day.  If on a run and I do turn the fridge on I find it cools pretty quickly too. 13MY Range Rover Sport Autobiography SDV6 - mine
|  Wed Jul 21 2021 8:08pm |
| Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274      | Mines on near constantly..... great for small drinks or pork pies  | ||
|  Wed Jul 21 2021 8:22pm |
| scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586    | RRSTDV8,
|  Tue Jul 27 2021 5:57pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Scrumps, you may have a fridge as it has been an option more recently.  In 2012, the cool box was purely a Peltier type cooler, not a fridge. 2012 SDV6 - it's missing a couple of cylinders
|  Wed Jul 28 2021 7:02am |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    |
 Use it only when you want it as it will drain your battery in quick order - 12 to 18 hours depending on temps and battery condition. They actually work quite well and it can cool a bottle or two just as quick as a proper fridge. Work even better if you put cool items in the fridge. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior | ||
|  Wed Jul 28 2021 8:21am |
| naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1210      | On mine the fridge only switched on when the ignition is on, so even if you leave it on all the time, it only cools when the engine is running. --
|  Wed Jul 28 2021 10:12am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | There was an issue with earlier versions where they could carry on drawing current even with the ignition off. I think they changed the design at some point. I seem to remember talk of a different colour light on the switch denoting the change. Green LED for old, Blue for later versions? It's been a while, so this is all a bit hazy. 2012 SDV6 - it's missing a couple of cylinders
|  Wed Jul 28 2021 11:23am |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    | My fridge runs independent of the ignition which means drinks stay cold when the car is off - thankfully the fridge fan is noisy enough to hear when the car is switched off and serves as a reminder to switch it off when the car is no longer needed for the day.
|  Wed Jul 28 2021 2:31pm |
| Posting Rules
