![]() | Home > General > Centre console fridge - always leave on? |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Only when using it, in my case. Can't see the point of using fuel to cool an empty box for no purpose. 2012 SDV6 - it's missing a couple of cylinders
| Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43
I thought that might be the case. Fridges are fairly power hungry appliances. |
It's not really a fridge as such, just a Peltier cooling device and an uninsulated box. 2012 SDV6 - it's missing a couple of cylinders
| insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533
I leave mine off all the time and find the cans left almost permanently inside (until drank) stay much cooler than if in the cabin on a hot day. If on a run and I do turn the fridge on I find it cools pretty quickly too. 13MY Range Rover Sport Autobiography SDV6 - mine
| Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274
Mines on near constantly..... great for small drinks or pork pies |
| scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586
RRSTDV8,
Scrumps, you may have a fridge as it has been an option more recently. In 2012, the cool box was purely a Peltier type cooler, not a fridge. 2012 SDV6 - it's missing a couple of cylinders
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
Use it only when you want it as it will drain your battery in quick order - 12 to 18 hours depending on temps and battery condition. They actually work quite well and it can cool a bottle or two just as quick as a proper fridge. Work even better if you put cool items in the fridge. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
| naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1210
On mine the fridge only switched on when the ignition is on, so even if you leave it on all the time, it only cools when the engine is running. --
There was an issue with earlier versions where they could carry on drawing current even with the ignition off. I think they changed the design at some point. I seem to remember talk of a different colour light on the switch denoting the change. Green LED for old, Blue for later versions? It's been a while, so this is all a bit hazy. 2012 SDV6 - it's missing a couple of cylinders
My fridge runs independent of the ignition which means drinks stay cold when the car is off - thankfully the fridge fan is noisy enough to hear when the car is switched off and serves as a reminder to switch it off when the car is no longer needed for the day.
| All times are GMT |
