![]() | Home > General (L494) > Another crank failure |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413 ![]() ![]() |
Where did you find that about the warranty bill? I agree I like the brand I like the car I just dont think the engine should have gone like it has and not be covered seeing as its not the odd one or two!
Lindlab yeah good point it was only if they had to update the ECU for the new engine but I think all they do is reset the error codes, as far as I am aware the ECU learns from the engine and how its driven etc... so they clear that so it starts as if its new.
AnotherMutley Member Since: 06 Mar 2018 Location: South East Posts: 16 ![]() ![]() |
Please don't get me wrong pjbracer, I love LR products and have owned them since they were owned by British Aerospace, I've had 2 DV6 engined cars, put over 100k miles on both without issue and waiting to hear about whether I'm ever going to get a build slot for a P400. My understanding is that if you buy your car from new, or from an LR dealer with Approved Used Warranty, JLR wouldn't leave you completely high and dry, that probably means you pay 80%, they pay 20% |
Mutley agree some people have engines that can go the distance but my point has always been where the car was bought and who from and how many owners is not really relevant for this particular problem as its deep inside the engine and no one has any control over it really, i get the engine should be serviced using the correct oils and genuine parts in accordance with manufacturer requirements (even if not at a dealer) and if this is the case then really LR should be offering a minimum of 20% assistance.
I think the whole issue of accountability for the crank failure on DV6 engines is a big issue for JLR because the origins of the engine, which is why they've moved away from them onto the straight 6 Ingeniums. My understanding is they were originally designed by PSM and then licensed to Ford to build, as well as being fitted in the Citroen, Peugeot and Jag. So when the Ford/JLR partnership ended in 2008, any redress for engine failure probably went the same way. I know that doesn't help us as customers but the other option is JLR payout for engine replacements then go the way of dozens of other british car manufacturers like Jensen, TVR, Triumph etc.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1200 ![]() ![]() ![]() |
Odd that only JLRs seem to suffer from the craink failure?
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
Not every user of these engines have the engine management allow 'regens' at any time, eg. when poodling around town.
Can you think of the last time you saw either a Citroen C6 or a Pug 407 coupe? Nope, me neither. |
+1 also for what Dave B said. |
@ DaveB I think it must be related in some way as this engine is used quite a bit (the short trips are impossible to tell from history) I do a few but I also do longer trips too I just dont do many trip in general.
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 390 ![]() ![]() |
How can forced regenerations lead to a crankshaft failure?
Under these conditions, extra fuel is introduced into the combustion chamber, if the engine is switched off during this operation, the excess fuel passes down the bore and in LRs case, drops onto the bearing cleaning it of oil.
It would be interesting to kno if all the failures of the past few years had oil tests at each service to see if dillution was a big contributing factor to the down fall!
It is not only short journey cars that suffer, for instance my Disco commercial will spend the day working hard pulling 2 - 3 tons or so, usually the majority of the time on the motorway, yet I can be parking it up at the yard, and it decides to regen, there seems no logic to the programming at all.
