Home > General > Rr sport 07, rear leak appeared this week |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8798 |
No photo visible or in your gallery. 2012 SDV6 - it's missing a couple of cylinders
Mon Jun 07 2021 3:52pm |
Benmtturner Member Since: 13 Nov 2020 Location: York Posts: 7 |
Sorry forgot to click upload. I've just had another poke around and belive it's the rear active anti sway bar |
Mon Jun 07 2021 3:55pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
theres pipes that feed that rear sway bar. are they leaking? |
Mon Jun 07 2021 5:11pm |
Yes, rear anti roll bar. If you're lucky it's the connections of the pipes to the bar. If not, it's a new bar assembly. Can be had for £700 from Advanced Factors, double that from a LR dealership. it's a bit of a fiddle to change - the rear body needs to be lifted a bit for access I believe. 2012 SDV6 - it's missing a couple of cylinders
Mon Jun 07 2021 9:15pm |
Thanks for the reply. I've ordered 2 new orings from jlr parts site. I'll clean it all up and fit over the weekend and see what's what. I o ly noticed it because of the small spot on the drive and I was un jamming my epb modual, its supposed to go for mot next week. I'm assuming this is an instant fail? |
Thu Jun 10 2021 2:40pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
I’m not 100% but I don’t see why it would be an immediate fail. The EPB is probably a more serious fail than a small leak. 2012 5.0 SC AB
Thu Jun 10 2021 6:27pm |
Epb it sorted now. New pads and disks all round. New shoes and cables for the park break. Just hoping I can get the mot so I've got a few days to get the roll bar sorted. |
Thu Jun 10 2021 7:46pm |
ive seen posts on here where it failed, but that could be due to the corrosion. if you just clean the area up and its a small leak you might get away with it |
Fri Jun 11 2021 11:09am |
Baker3570 Member Since: 28 May 2021 Location: cumbria Posts: 51 |
hi sorry for jumping on your post,
Fri Jun 11 2021 2:17pm |
probably not. you can take a few bottles with you, but ACE runs at high pressures which means fast leaks.
Fri Jun 11 2021 2:27pm |
ahh right im with you.. i know it sounds daft but would taking it easy help or still the same?
Fri Jun 11 2021 2:30pm |
still the same. mine managed to puke all the oil from just idling 😂
Fri Jun 11 2021 2:51pm |
ok thank you for that... |
Fri Jun 11 2021 3:11pm |
