Home > General > Nightmare
Page 3 of 4 <1234>
RRT
I think if I were in your position, once the car is returned to you, I would immediately take it to a trusted LR specialist for a check over to make sure the installations has been carried out correctly and the new engine is healthy. It might cost you a couple of hundred, but gives you peace of mind. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #612835 Wed Apr 21 2021 6:03pm
Kitchenfitter
Mer tomoay well do that i will call my local dealer tomorrow
Post #612840 Wed Apr 21 2021 7:26pm
1richard1
Well if they dont change the belts etc, and you have 3 months warranty then for the 3 months i would drive it like you stole to put it under some reel stress (within the law of course Whistle ) any thing at all that sounds slighty off, bounce it back under warranty, untill your happy.
Post #612848 Wed Apr 21 2021 9:43pm
Lindab
Lot of negative posts there to cause you some worry. If I was the dealer, after all the bother you have had & cost & time to them, they don't want the car coming back after fitting the new engine. I am sure they will do a good job. It's not worth their reputation to do shoddy work & its just as easy to do a good job as a bad one. It's typical forum posts, every garage is Censored & they are all out to screw you. I don't see why you need to take it elsewhere to check its been fitted properly, what's to see unless they are going to do compression tests, borescope, see if the oil was changed, drop the sump etc. Yes get that done but it will be more than a couple of hundred pounds. Anyone buying a second hand car, how do you know how the engine was treated, even one with a prefect MOT history (the old chestnut of the old lady who drove around everywhere in first gear as she didn't want to go very fast) but was always serviced on the button
Its got a warranty, they don't want to see it again Thumbs Up
Post #612851 Thu Apr 22 2021 9:15am
Kitchenfitter
Thank you for your point of view its a scary time [/img]
Post #612870 Thu Apr 22 2021 6:01pm
1richard1
Lindab the reason for the more hostile posts are the garage only offered £500 for the engine failure and saying not covered by the warranty, it was only when the finance company stepped in that they agreed to do anything (maybe because it would cause them a bigger issues long term with finance companys), so i would think they are going to do it cheap as possible to cover the true cost (if they slap an engine that lasts more than 3 months they are covered), if they wanted a good reputation they would have put it right first time or offered a refund, not being forced to do the work. Just my opion.
Post #612876 Thu Apr 22 2021 8:37pm
Lindab
Wrong post
Post #612900 Fri Apr 23 2021 12:11pm
Kitchenfitter
According to the Finance broker should have my RRSA back Monday with replacement engine fitted so hopefully ally being well can give the the Musty a rest lol
Post #613887 Fri May 21 2021 7:45pm
Kitchenfitter
Finally got RRS back yesterday and so far all seems goid 🤞
Post #614027 Wed May 26 2021 9:17pm
Flyfisherman
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
That’s great news. May you have many thousands of trouble free motoring.
Post #614031 Wed May 26 2021 10:59pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Glad to hear that it's all been repaired & hopefully to a good standard , time to enjoy it now .
Post #614042 Thu May 27 2021 8:19am
Kitchenfitter
Car drives fine changing through gears smoothly etc
Check oil when cold and says oil overfill but after being used and leaving it for 20mins i check again and says oil level max and ok
I get a oil burning smell occasionally and assume its because engine has just been fitted ?
Although today had some very faint oil smoke from bonnet area - not a fire - could this be a breather pipe ?
Will be contacting garage tomorrow
Post #614128 Sun May 30 2021 7:16pm
Dave-t
It’s not right if it says overfill, it’s either too much or a dodgy sensor, make sure you report it in wring (e mail or letter) so it’s recorded. Joined the X5 45e club
1994 Defender 90 300 tdi
Post #614130 Sun May 30 2021 8:39pm
Kitchenfitter
Will do as need it sorting
Post #614132 Sun May 30 2021 8:41pm
Themoog
No no no. You need CA to send you a draught letter that you put your details in and faults with the vehicle. Then send it to the dealer via signed for post.
By law they have to attempt to repair it first. If that is not satisfactory then refund.
In this instance I would imagine they will just refund and the vehicle will be written off. I've been there and done it so I know.
I also have a close friend who is a car dealer and he is the one who told me what to do.
Ignore all that as I've just seen that you have it back..
Post #614199 Wed Jun 02 2021 6:02am
Page 3 of 4 <1234>
