![]() | Home > Faults & Fixes > N/S/F Rattling at Speed? |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 79 ![]() ![]() ![]() |
Hi Everyone.
Thanks. I'll go and check that out... |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 748 ![]() ![]() ![]() |
Initial thoughts are:
Hi Steve
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1045 ![]() ![]() ![]() |
From what you've said Phil, I assume you've checked the vent on the wing?
Thanks everyone. The bonnet seems ok, the sidestep seems ok and the mudflap is hand tight, so I am still looking. I'll check the vent but again, its hand tight and doesn't seem to move.
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 139 ![]() ![]() ![]() |
Have you had a new window screen recently? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 3464 ![]() ![]() ![]() |
Yeah had a similar issue after having screen replaced, turned out to be broken clip at top of screen pillar trim, replaced all the clips and noise disappeared.
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1794 ![]() ![]() ![]() |
Lots of things to check and likely a case of checking everything one at a time.
blastcleaner Member Since: 26 Feb 2012 Location: Sussex / Surrey border, UK Posts: 4 ![]() ![]() ![]() |
I had a similar problem long ago and found it was the top of the windscreen rubber getting high speed air under it and causing it to flap basically like the reed in a musical instrument. Sounds unlikely and that is exactly why it was hard to pinpoint. Get a roll of good quality duct tape and after thoroughly cleaning the rubber along the top of the screen - tape all along then test drive. Tip, don’t leave the tape on for more than a day or so or in sunny hot conditions or you will take a week to get it off again. Peel back on itself is the best way to avoid it tearing. 4 Landrovers and 7 Range Rovers in 40 years.
Elgrimio Member Since: 22 Nov 2020 Location: St Albans Posts: 2 ![]() ![]() ![]() |
I had exactly the same thing as blastcleaner and it sounds as though it's coming from inside the door but it was the plastic runners joining up to the top of the windscreen that had some loose so the wind was getting underneath it at around 70mph.
Thanks everyone and sorry for my delayed reply! I've taken my side steps off now and its not quite as bad, they were very badly corroded underneath with bits of loose metal, so they went in the skip!
and the problem was..... a trim clip missing from the black weather strip on the roof! it left a small hole which the wind got inside off and made the noise. A bit like when you blow over the top of a bottle.
Site Copyright © 2005-2021 Futuranet Ltd & Martin Lewis
