Home > Faults & Fixes > N/S/F Rattling at Speed?
PeteF74
United Kingdom 2011 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi Everyone.
At about 80 on the motorway and generally when the n/s/f is into the wind, I get a rattling sound coming from front passenger door area?
It doesn't seem to be internal (so no its not the Mrs talking!) as the interior is pretty much rattle free. Its not constant and goes when you drop below 80.
I have checked all the exterior trim, mirrors, pillar covers etc and it all seems solid. Nothing is loose. I wouldn't think it was buffeting because it doesn't happen when the drivers side is into the wind.
Any ideas??? - and please don't say don't do 80! Laughing
Post #605769 Tue Oct 20 2020 1:52pm
Is the bonnet correctly closed? I have found on occasion that the passenger side hasn't latched and so can vibrate with airflow. The bonnet closed switch is on the driver's side latch which is why it might occur without you noticing. 2012 SDV6 - it's missing a couple of cylinders
Post #605774 Tue Oct 20 2020 3:13pm
PeteF74
Thanks. I'll go and check that out... Thumbs Up
Post #605776 Tue Oct 20 2020 5:08pm
Stevepd
Initial thoughts are:
Loose mud flap (if fitted)
Loose trim strip on the foot step
Everything tightened up underneath in that corner 2006 2.7 TDV6 HSE in Cairns Blue.
Post #605798 Wed Oct 21 2020 7:36am
PeteF74
Hi Steve
I hadnt checked those things as I was working higher up the car as thats there I thought it was coming from.
I do have both on mine, so will go and check them out. Thumbs Up Thumbs Up
Post #605802 Wed Oct 21 2020 9:39am
knwatkins
From what you've said Phil, I assume you've checked the vent on the wing?
On mine, whilst it didn't make a noise when travelling, I think a clip was missing and could be rattled by hand. I took it off and bonded it on with some clear silicone. Problem solved. Kev
Post #605835 Wed Oct 21 2020 11:50pm
PeteF74
Thanks everyone. The bonnet seems ok, the sidestep seems ok and the mudflap is hand tight, so I am still looking. I'll check the vent but again, its hand tight and doesn't seem to move.
I think its going to be a strange one. Marble in the ashtray kind of thing.
Post #605889 Fri Oct 23 2020 2:47pm
1richard1
Have you had a new window screen recently?
Post #605891 Fri Oct 23 2020 4:14pm
Yeah had a similar issue after having screen replaced, turned out to be broken clip at top of screen pillar trim, replaced all the clips and noise disappeared.
Post #605899 Fri Oct 23 2020 10:53pm
Brit Plumber
Lots of things to check and likely a case of checking everything one at a time.
For my thoughts in addition to those mentioned.
There’s that pointless bag thing behind the wing that everyone thinks is rubbish.
The black rubber strip in the roof gutter.
A chattering windscreen wiper if it doesn’t have the spoiler or upside down.
Wheel school liner clips missing.
As mentioned. Loose trim on the side step is a good call. Both my trims have popped the first rivets. You may need to look at the back to check rather than rely on trying to move the trim. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #606173 Mon Nov 02 2020 8:55pm
blastcleaner
I had a similar problem long ago and found it was the top of the windscreen rubber getting high speed air under it and causing it to flap basically like the reed in a musical instrument. Sounds unlikely and that is exactly why it was hard to pinpoint. Get a roll of good quality duct tape and after thoroughly cleaning the rubber along the top of the screen - tape all along then test drive. Tip, don’t leave the tape on for more than a day or so or in sunny hot conditions or you will take a week to get it off again. Peel back on itself is the best way to avoid it tearing. 4 Landrovers and 7 Range Rovers in 40 years.
Series I, II, IIA, III, Classic, Classic, Schuler, Overfinch, P38, L322, Sport.
A Love / hate relationship, when they work I love them..... you can figure the rest for yourself.
Post #607171 Wed Dec 02 2020 11:26pm
Elgrimio
United Kingdom 2008 Range Rover Sport TDV6 HSE Siberian Silver
I had exactly the same thing as blastcleaner and it sounds as though it's coming from inside the door but it was the plastic runners joining up to the top of the windscreen that had some loose so the wind was getting underneath it at around 70mph.
Stuck it down, never came back.
Felt sorry for the lady who owned the car before me, looking at the invoices for work she'd had done I could see she'd paid loads of an Indy to try and investigate the sound.
Post #607483 Mon Dec 14 2020 7:32pm
PeteF74
Thanks everyone and sorry for my delayed reply! I've taken my side steps off now and its not quite as bad, they were very badly corroded underneath with bits of loose metal, so they went in the skip!
Debating whether I prefer the car with or without the steps?!
The trim strip on the roof was a bit raised, so I pushed that back home properly and will give that a try.
Definitely going to try and locate this myself and not spend a fortune having it checked. Pete
2011 SDV6 HSE - Owned since July 2020
1989 Range Rover Classic 3.5 Vogue Manual - sold
Post #608188 Tue Jan 05 2021 5:32pm
PeteF74
and the problem was..... a trim clip missing from the black weather strip on the roof! it left a small hole which the wind got inside off and made the noise. A bit like when you blow over the top of a bottle.
Sorted with an 87p clip and now completely silent Thumbs Up Pete
Post #610439 Tue Feb 23 2021 11:30am
Stevepd
Tremendous. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #610457 Tue Feb 23 2021 4:34pm
