Home > Maintenance & Modifications > Gear box oil change or flush? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4876 |
being at the bottom of the world gravity should help your pressure sprayer out a bit.
Mon Jan 04 2021 9:49pm |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 |
Thanks for the offer, I may take you up on that and obviously compensate you with beer tokens |
Tue Jan 05 2021 10:47am |
Hi, I would just confirm what they do with their Megaflush as a Flush is normally some form of Transfusion of the oil to replace most of it, if they are suggesting replacing the filter then believe that involves dropping the transmission sump so wonder how they replace the oil, before or after filter changed, I dont know Always a good idea to change a filter mind, so just confirm what and how they do it. and at your mileage its well worth doing Our 2006 we had a flush/transfusion on our drive done as preventative, no issues before or after and the 2010 we had I dropped the oil with a plan to do a few more changes over the coming months, again preventative with no issues before or after ....... but we then sold it before another change was done Porsche Cayenne 2022 gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
Tue Jan 05 2021 3:03pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I have slight vibration felt through the floor, seat, steering wheel at about 30mph to 40mph during moderate acceleration. Got my indie to test drive it just before Christmas and he's pretty sure that a gearbox "Powerflush" will cure it, There is a concern that it might be the torque converter on its way out if the flush doesn't work.
Tue Jan 05 2021 5:00pm |
Lhard92 Member Since: 31 Dec 2020 Location: Bristol Posts: 21 |
I’m all booked in the Bodsy now. He will be doing megaflush but not changing filter so sounds good to me! Offers a huge list of other services too which I might be sucked in to lol. Thanks
Thu Jan 07 2021 4:24pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
You won't go wrong with Bodsy. He did flushed Rob's and Steve's on here a couple of years back. Kev
Thu Jan 07 2021 4:33pm |
Just back from my Indie. Cost of the Powerflush including an additive (?) was £277 and no vibration. If that lasts another 20,000 miles or so before I need to fork out on a new torque converter, then I'm happy. Especially as I'm not doing many miles at the moment. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Thu Jan 07 2021 4:44pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 |
Bodsy is your man He also does transfer and diff oils. Peace of mind Also does remaps Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Thu Jan 07 2021 9:44pm |
Yep I’m definitely interested in the mapping too. What is the diffs and transfer box oil change? Did notice that on his price list but no idea what it is for? Thanks
Thu Jan 07 2021 11:49pm |
Diffs = front and rear axles. Do it.
Fri Jan 08 2021 10:13am |
^^^ as above. The fluids are the life blood of your components. It's important they are drained and refilled at the required intervals to keep everything tip-top. Kev
Fri Jan 08 2021 10:27am |
Not a major concern but just thought would mention it if anyone was going to do the transmission oil themselves on a S/C, it would appear to have a different oil cooler although the principle is exactly the same, access to the pipes may even be easier than the 3.0L but obviously wouldn't know. I think I have marked flow direction correctly as haven't done the change yet just looking to see what is involved.
Sat Jan 09 2021 1:05am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4349 |
They look the same connectors as FL2/405/494 |
Sat Jan 09 2021 9:28am |
It was a guess for me when I did the 3.0.
Sat Jan 09 2021 12:53pm |
