Home > General > Vibration under light load |
My TDV8 has developed a slight vibration when under light acceleration or gently climbing a hill. It is beginning to get worse and is occasionally becoming apparent whilst cruising at between 40mph and 50mph. Of course its appears to be an intermittent fault as I can't always notice or replicate it. Quite annoying on a recent 40mile trip to the extent that I did not stray above 40mph at any point just to avoid the possibility of it happening. And as it appears to be getting worse I am starting to get worried. If I slip the car into neutral whilst doing say 45mph the vibration still remains so I don't think its engine related.
Tue Dec 22 2020 3:31pm |
I'll have a look, Cheers Robin
Tue Dec 22 2020 4:45pm |
I managed to get it to my indie briefly yesterday afternoon for a test drive. Fortunately the intermittent fault wasn't that intermittent and my mechanic could feel the vibration.
Wed Dec 23 2020 10:33am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8828 |
If it is the torque converter then a flush should help with the symptoms. But if the torque converter clutch has started to judder then it's "on its way out". As I understand it, the clutch becomes contaminated and that's what causes the judder. The flush doesn't remove the contamination but it reduces the rate at which it will accumulate as the fresh oil doesn't contaminate it.
Wed Dec 23 2020 10:57am |
Fingers crossed... Robin
Wed Dec 23 2020 11:00am |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Wed Dec 23 2020 3:25pm |
My Indie described the last one as a Powerflush - cost about £250. Well if they do it and it doesn't work I'll be looking to them to look further and not slap one charge on top of another. I can get that sort of service at a dealer and I expect more from an Indie. Robin
Wed Dec 23 2020 4:59pm |
Just back from my Indie. Cost of the Powerflush including an additive (?) was £277 and no vibration. If that lasts another 20,000 miles or so before I need to fork out on a new torque converter, then I'm happy. Especially as I'm not doing many miles at the moment. Robin
Thu Jan 07 2021 4:47pm |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 134 |
Hi I have a 2008 tdv8 and it's covered 115k my torque converter did same thing nearly 2years ago 15k miles ago so I had the same flush and additive and it's been no bother since so hopefully you'll be ok 👍 |
Wed Feb 10 2021 6:19pm |
Good to know. Fingers crossed 🤞 Robin
Wed Feb 10 2021 6:52pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
The "additive" that has been mentioned is most likely "Dr tranny" it's a friction modifier to help reduce shudder in torque converters,, normally add a couple of tubes when carrying out a flush. 2010 RRS, TDV8
Wed Feb 10 2021 8:33pm |
