Home > Maintenance & Modifications > Gear box oil change or flush?
Page 2 of 3 <123>
knwatkins
I'm sure we could do it with my el-cheapo pressure sprayer and a bit of extra long hose Col Rolling with laughter Kev
Post #608161 Mon Jan 04 2021 9:18pm
Thumbs Up being at the bottom of the world gravity should help your pressure sprayer out a bit. Laughing
Post #608162 Mon Jan 04 2021 9:49pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Quote:
"knwatkins" Nilrem280 - I'd be happy to do it for you when it warms up a bit outside.
Thanks for the offer, I may take you up on that and obviously compensate you with beer tokens Thumbs Up
Post #608174 Tue Jan 05 2021 10:47am
riverblanche
Lhard92 wrote:
for megaflush. They upselled having the filter changed Car is on 116k miles...
I would just confirm what they do with their Megaflush Question
as a Flush is normally some form of Transfusion of the oil to replace most of it, if they are suggesting replacing the filter then believe that involves dropping the transmission sump so wonder how they replace the oil, before or after filter changed, I dont know Confused
Always a good idea to change a filter mind, so just confirm what and how they do it.
and at your mileage its well worth doing Thumbs Up
Our 2006 we had a flush/transfusion on our drive done as preventative, no issues before or after
and the 2010 we had I dropped the oil with a plan to do a few more changes over the coming months, again preventative with no issues before or after
but we then sold it before another change was done Rolling Eyes
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #608180 Tue Jan 05 2021 3:03pm
Eaters
I have slight vibration felt through the floor, seat, steering wheel at about 30mph to 40mph during moderate acceleration. Got my indie to test drive it just before Christmas and he's pretty sure that a gearbox "Powerflush" will cure it, There is a concern that it might be the torque converter on its way out if the flush doesn't work.
I last had it flushed by the same indie 3 years ago and 27,000 miles ago. Cost then was £252. It goes in this Thursday so I'll report back on developments if that helps the OP or anyone else for that matter
My concurrent post is at https://www.rrsport.co.uk/forum/topic57395.html Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #608184 Tue Jan 05 2021 5:00pm
Lhard92
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I’m all booked in the Bodsy now. He will be doing megaflush but not changing filter so sounds good to me! Offers a huge list of other services too which I might be sucked in to lol. Thanks
Liam
Post #608261 Thu Jan 07 2021 4:24pm
knwatkins
You won't go wrong with Bodsy. He did flushed Rob's and Steve's on here a couple of years back. Kev
Post #608263 Thu Jan 07 2021 4:33pm
Eaters
Just back from my Indie. Cost of the Powerflush including an additive (?) was £277 and no vibration. If that lasts another 20,000 miles or so before I need to fork out on a new torque converter, then I'm happy. Especially as I'm not doing many miles at the moment. Robin
Gone:
MGZTT 190 2.5
Post #608265 Thu Jan 07 2021 4:44pm
DrRob
Bodsy is your man Thumbs Up
He also does transfer and diff oils. Peace of mind Thumbs Up
Also does remaps Whistle Bow down Visitor from fullfatrr.com
Post #608290 Thu Jan 07 2021 9:44pm
Lhard92
Yep I’m definitely interested in the mapping too. What is the diffs and transfer box oil change? Did notice that on his price list but no idea what it is for? Thanks
Liam
Post #608293 Thu Jan 07 2021 11:49pm
DrRob
Diffs = front and rear axles. Do it.
Transfer box = the 4x4 bit. Do it.
Preventative maintenance is key.
Remap = for yours the ECU will need to be removed and sent away. He'll tell you that. Visitor from fullfatrr.com
Post #608302 Fri Jan 08 2021 10:13am
knwatkins
^^^ as above. The fluids are the life blood of your components. It's important they are drained and refilled at the required intervals to keep everything tip-top. Kev
Post #608303 Fri Jan 08 2021 10:27am
Not a major concern but just thought would mention it if anyone was going to do the transmission oil themselves on a S/C, it would appear to have a different oil cooler although the principle is exactly the same, access to the pipes may even be easier than the 3.0L but obviously wouldn't know. I think I have marked flow direction correctly as haven't done the change yet just looking to see what is involved.
Post #608352 Sat Jan 09 2021 1:05am
Disco_Mikey
They look the same connectors as FL2/405/494 Thumbs Up
Post #608355 Sat Jan 09 2021 9:28am
knwatkins
It was a guess for me when I did the 3.0.
Just disconnect both and hold over the bucket whilst your assistant turns the engine on, Col. It's surprising how fast the fluid comes out Very Happy Kev
Post #608361 Sat Jan 09 2021 12:53pm
Page 2 of 3 <123>
