![]() | Home > Technical > Battery Options |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5087 ![]() ![]() ![]() |
That is crap, it is advised to reset BMS after fitting new battery, but they will recalibrate themselves over time buy I'm sure a Indi will do it cheap enough though, I replaced mine 4 years ago and never reset anything and never had a issue, buy a battery from the likes of Tanya and fit it yourself, just make sure the battery is fully charged before fitting.
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 475 ![]() ![]() |
Thank you,
Yes, no problem there are a few options in there to change battery capacity if you fit a different rated one, but not sure if it really makes a difference. |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
As Col says the battery monitoring system will, over a short time, work out what type of battery has been fitted ie an AGM or non AGM.
I actually replaced the original factory Wet battery for a larger capacity 95Ah 850A AGM on my S/C, as they only ever fitted 700A Wet to the petrol RRS1's for some reason and as said never changed anything and never had a problem.
Don’t buy a YUASA 019, I’ve Been through 3 in 18 months under warranty and now have an AGM. 2019 5.0 SC SVA (Current)
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9083 ![]() ![]() ![]() |
Why are you using a dealer on an 8 year old vehicle? You may as well just walk in with your trousers around your knees and bend over in front of the service desk. Get thee to an indie, save a load of money and get better treatment. £400 to replace a battery. Really? FFS. ![]() 2008 TDV8 - it was a labour of love and is much missed |
I’ll change your battery for £400 |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
To be fair to Neal, he may not be too mechanically minded. Its (unfortunately) because of customers like this that the RAC etc can charge such outrageous fees for simple stuff. Thing is, we know that a battery change is not hard and that's why we visit forums like this to pass on knowledge. |
Forgot to come back on this,
No problem using a Stop/Start AGM battery, had a Varta one on mine for nearly 5 years with no problem.
Thank you Col.. ===========================================
