Home > Maintenance & Modifications > Tyre Pressure Warning Fault? |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 83 |
Hi
Sun Sep 13 2020 8:29pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
May be tps batteries need replaceing |
Sun Sep 13 2020 9:52pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
On mine the TPMS warning light doesn't come on till pressure drop to around 25psi as previously let a couple of tyres down to see what it did. Having seen some sensors and not sure you can change a battery in them as they looked sealed in, so think it may be new sensor but not certain on that one. Might be worth checking the aerial/initiator bit wiring etc. inside the wheel arch, also would have thought a faulty sensor would log a fault code so they may need reading.
Sun Sep 13 2020 11:43pm |
Thanks everyone. I found out what it was today....
Tue Sep 15 2020 7:24pm |
Would have thought 33psi in the rears is a bit low, personally always run at least 36psi in rears.
Tue Sep 15 2020 10:24pm |
Thanks Col I will check my door sticker again and see what it says. |
Wed Sep 16 2020 9:20am |
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 |
I'm getting this fault showing on the spare. The car is only six months old, & I've checked the spare & it's 40psi, but it warns it's low each time I start the car. current 2015 hse dynamic, grey. |
Wed Sep 16 2020 12:44pm |
Running 36 on the rears now. Much better Thanks Col |
Mon Sep 21 2020 8:34pm |
