Home > Maintenance & Modifications > Tyre Pressure Warning Fault?
PeteF74
United Kingdom 2011 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi
My tyre pressure warning light came on today, saying the pressure in the right front tyre was low. I checked the pressure and it was only a few psi down, so I pumped the tyre up to 33 and checked the car again but the light was still on? I drove off and went about my business, turning the car off and on a few times and driving at least 30 miles but the light is still on.
I am therefore thinking I have a tyre pressure sensor fault or an abs sensor fault? I had an abs sensor go on my last car and it somehow doesn't feel like that happening on the RRS.
I can't see any signs of a puncture either, which was something else that crossed my mind.
Has anyone else had this issue and what did it turn out to be? or am I doing something wrong? Can it be re set somehow?
Thanks.
Post #604523 Sun Sep 13 2020 8:29pm
1richard1
May be tps batteries need replaceing
Post #604524 Sun Sep 13 2020 9:52pm
On mine the TPMS warning light doesn't come on till pressure drop to around 25psi as previously let a couple of tyres down to see what it did. Having seen some sensors and not sure you can change a battery in them as they looked sealed in, so think it may be new sensor but not certain on that one. Might be worth checking the aerial/initiator bit wiring etc. inside the wheel arch, also would have thought a faulty sensor would log a fault code so they may need reading.
Post #604527 Sun Sep 13 2020 11:43pm
Tyrefitter
Swap a wheel front to rear or side to side & that will tell You if it’s the sensor or the detector in the arch.you cannot change batteries,it is a full sensor swap & if that’s the case I would get a full set (about £80) if ones gone the rest won’t be far behind. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #604530 Mon Sep 14 2020 5:09am
PeteF74
Thanks everyone. I found out what it was today....
I noticed that the car was set to 'heavy load' for the tyre pressures, so it was expecting 37/38 psi when I was going to only 33 psi for max four passengers.
I reset the car to 'light load' made sure I was at 33 psi all round and the warning light has gone out.
Simple as that. Feel a bit stupid for not seeing that sooner Whistle but at least it means I don't need a trip to the garage.
Post #604579 Tue Sep 15 2020 7:24pm
Would have thought 33psi in the rears is a bit low, personally always run at least 36psi in rears.
Post #604581 Tue Sep 15 2020 10:24pm
PeteF74
Thanks Col Thumbs Up I will check my door sticker again and see what it says.
Post #604585 Wed Sep 16 2020 9:20am
pko
England 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I'm getting this fault showing on the spare. The car is only six months old, & I've checked the spare & it's 40psi, but it warns it's low each time I start the car. current 2015 hse dynamic, grey.
Post #604594 Wed Sep 16 2020 12:44pm
PeteF74
Running 36 on the rears now. Much better Thumbs Up Thanks Col
Post #604737 Mon Sep 21 2020 8:34pm
