![]() | Home > Maintenance & Modifications > Red battery urgent |
Craigb86 Member Since: 09 Jul 2020 Location: Wales Posts: 74 ![]() ![]() |
Well ive booked in for alternator this morning along with a list of stuff so it would be Ideal if those results point to alternator
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9109 ![]() ![]() ![]() |
Bear in mind that a dodgy battery can kill an alternator. Be prepared to replace both but hope only the alternator is required. 2012 SDV6 - it's missing a couple of cylinders
Yea im prepared for that and almost tempted for sake of £150 more for new battery same time then kts warrantied |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5115 ![]() ![]() ![]() |
Dennis, does it matter which side of the BMS module the neg. terminal is connected? Cheers Col |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Col, I'm not 100% sure what you mean, I fitted the monitor unit inside the battery box and connected to a spare threaded hole on the +ve battery clamp then ran the -ve lead out of the battery box to an earth point just outside. There are red & black coloured fork crimps aleady fitted so I assume is polarity sensitive. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5114 ![]() ![]() ![]() |
It's not drawing any significant current so I don't think it matters to the car.
Dennis, I assumed the monitor connected direct to pos. and neg. battery terminals, but as on the sport the BMS bolted on the neg. terminal post just wondered if it made a difference as when hardwired a ctek plug in it was recommended the neg. terminal was connected to earth point on the vehicle not the neg. battery terminal, I realise the ctek and the monitor serve two different purposes, but just wondered if it made a difference as would not describe myself as a auto electrician. |
Col, I never thought much about it, I probably would have gone directly across the battery except the -ve was tucked under the scuttle panel area so a pest to get to (probably battery out), I chose the external earth out of lazyness |
I'm curious as to why the engine idle volt readings seem to be the focus but not when the engine has higher rev's?
Under load it counted down none stop from 13 to 11.9 before i turned it off so it didn't drop too low to cause more damage. As you said I put on high beam and heater to create load and it was losing voltage as fast as counting down would be |
A good battery should have held that load for a while before dropping to that level, especially if not long since being charged. But it's quite common for a knackered battery to take out the alternator aswell. 13MY Range Rover Sport Autobiography SDV6 - mine
Well alternator is booked in so will get a battery myself and leave it in passenger footwell and say once the alternator is fitted change battery
