Home > Maintenance & Modifications > Red battery urgent
Page 2 of 3 <123>
I'm putting my beer tokens on it being the alternator having died. 2012 SDV6 - it's missing a couple of cylinders
Post #604349 Wed Sep 09 2020 9:10am
Craigb86
So daft question as a newbie can I drive it as I pick my daughter up for access weekend
Post #604350 Wed Sep 09 2020 9:13am
Craigb86
as in would I cause damage to car
Post #604351 Wed Sep 09 2020 9:13am
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
For folks not too clued up on basic electrics then a cheap little tool can provide good info on what's going on with the battery and charging system without having to figure out a multimeter (yes a multimeter is invaluable in knowledgeable hands). It's a BM2 battery monitor which is left permanently attached to the battery which connects to your phone etc. via blutooth and stores volt data for 28 days. Even for folk familiar with a multimeter this is a handy tool (I've got 27 years experience using them for work)
Here is a few screenshots of the charts.
Charging using a Ctek MSX10. I put the charger on shortly after getting home after a drive whcih is shown by the charging rise then drop then a long rise.
A couple of short drives, the blips towards the right are the vots drop when the doors were opened on my drive. My battery is good, so the amount of volt drop shows how much power the RRS uses just by wakening up.
Yesterdays drive to and from work which shows a volt drop before the alternator charging rise which is the timed heater running.
Here's another post on it - https://www.rrsport.co.uk/forum/topic55430.html with eBay link, or you can get cheaper if not in a hurry by buying of Aliexpress. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #604352 Wed Sep 09 2020 9:44am
Craigb86
Just order that one it makes sense to have that view defo and I've booked the car in for some other jobs that needed doing and will get new alternator same time as its cheaper then and looking on the forum these cars seem to poop alternators so its likely to be nearly dead anyhow so I don't think its a bad move would you say?
Post #604359 Wed Sep 09 2020 11:51am
syl
You can usually pick a multimeter up same day from Screwfix for less than £10. If the one you ordered doesn’t arrive, get one there and send the other one back. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #604360 Wed Sep 09 2020 11:57am
does that battery monitor give you any indication like the ctek traffic light system? (via the app) ?
OP - No you won't damage your car. The worry is if you drive all the way with the light on (and thus no charging) you may break down. (don't use any electrical stuff if its stuck on. e.g heaters, fans)
The only way it could get damaged is if its reading 16V or over when you measure it with engine on.
When it arrives, you want the red lead in the V hole.
And get it to volts DC. Dunno how.
Post #604361 Wed Sep 09 2020 11:59am
Craigb86
Will do its in 12th October for all my other work from the car dealer being underhand so ots had its safety check for small claims court case so may as well sort the alternator at same time just billed separate job then
Volt meter will hopefully confirm if battery is dead too its an oldham batter so not sure of its age really
Post #604363 Wed Sep 09 2020 12:44pm
Craigb86
OK so I quickly checked on my lunch break
Engine off but terminal still connected (no key in) was 12.35
Engine on idle 13.2 to 13.6 more toward lower end though of that
Post #604373 Wed Sep 09 2020 3:23pm
Craigb86
let me know if i should do one terminals off as i can do that once I finish at 5 i tried to squeeze it in while munching my sandwich as I only get 20 mins lol
Post #604374 Wed Sep 09 2020 3:25pm
The battery is about 70% charged so that's good (unless it was fully charged beforehand). The idling voltage looks a bit low. If you turn on some decent load - heated screen, for example - what does the voltage do then? 2012 SDV6 - it's missing a couple of cylinders
Post #604377 Wed Sep 09 2020 4:33pm
Craigb86
Will check that now and my charger said it was full but its only a little charger I will nip straight out at 5 and grab a few tests is there any other to try to give most idea as possible
So terminal off
Terminal on
Idle
Then idle with load
Can you think of any more
Post #604378 Wed Sep 09 2020 4:36pm
insiorc
Are you meaning the Ctek monitor? If so I've never seen it, but it's nothing like that useless Ctek traffic light on the charger connector, I have one of them but now ignore the lights, I would only suggest people spend the extra on them as the leads are fused.
Here are some screenshots showing the other displays and options;
The live voltage screen with instantaneous graph (history as shown in graphs posted earlier is graphs at 2 minute intervals)
Settings
Alternator test at idle and high revs (I think 2500rpm but not positive)
Cranking test
Trip history
Post #604379 Wed Sep 09 2020 4:42pm
Craigb86
No the volt meter i got delivered today
Post #604380 Wed Sep 09 2020 4:56pm
Craigb86
OK so got this
Idle no load 13 average
Idle load 12.6 then counted down almost as fast as seconds so turned engine off at 12.2
No battery connection 12.29
Then battery connected side lights 12.22
Thats in order too
Post #604381 Wed Sep 09 2020 5:11pm
Page 2 of 3 <123>
