Home > Maintenance & Modifications > Red battery urgent |
Craigb86 Member Since: 09 Jul 2020 Location: Wales Posts: 74 |
I'm hoping its OK as its on connected and charging but with trickle smart one noco genius 1 I'm not even sure its powerfull enough on this car to charge it |
Tue Sep 08 2020 3:59pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 916 |
First thing I would do is check the voltage when at idle just to make sure the alternator is doing its job,,, you should see more than 14V. It's not a problem charging the battery with it connected but I think landrover recommend connecting to the positive terminal and the earth on the body when charging. I would not reallydrive it far until you find out what is at fault,, good chance it's the battery if it's more than 4 or 5 years old, but it could fail completely at any time if that is the fault. I wouldn't be too worried about taking the battery off,, i've done mine a few times and never needed a code to reinstate anything. 2010 RRS, TDV8
Tue Sep 08 2020 4:06pm |
Would you say to buy volt meter or use those funds to bit bullet on battery |
Tue Sep 08 2020 4:40pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
If the car starts, it’s not the battery. (Or unlikely ) |
Tue Sep 08 2020 5:11pm |
Well,,,, I would disagree slightly as twice I the past I have had a faulty battery,,, but the car still started,,,, the problem being the battery was only retaining 60% of its full charge and after a few short runs it would not start the car. What I didn't get was a red warning on the dash which is why I say check the voltage,, it can point you in the right direction. Doyou not know anyone who can check it for you if you don't own a meter??. Visit a garage and have them check it for you,, might well be an alternator fault if the red light persists. 2010 RRS, TDV8
Tue Sep 08 2020 5:27pm |
I just had on charge for hour and its gone off now so put it back on charge if its gone off now its disconnected would thaf signal battery?
Tue Sep 08 2020 5:30pm |
Charging a battery for an hour will not do much good,,, charge it overnight. You can charge a faulty battery and it may look OK,,,, but as soon as you put it to use it will revert back to its faulty state,,, a cheap multimeter is a handy piece of kit to have in your toolbox,, as I say, it can point you in the right direction before you start spending money.,,, but you say youhave a warning on the dash which makes me think alternator,,,, but it's all guess work unless you test the voltages. 2010 RRS, TDV8
Tue Sep 08 2020 5:54pm |
Does it need to be a certain type of tester im just on amazon now will order one prime to try tomorrow then |
Tue Sep 08 2020 6:14pm |
Tue Sep 08 2020 6:22pm |
Ordered different one as had 7 mins left to order for tomorrow lol |
Tue Sep 08 2020 7:02pm |
Went for that hopefully its not terrible I didnt go for cheapest but didn't go nuts
Tue Sep 08 2020 7:24pm |
That good enough for most basic tests. Set it to DC volts and check across the battery terminals with the engine running,, you should see in the region of 14.6V. With the engine off,, 12.6V would indicate a full charge,,, low 12V readings points toward a discharged / faulty battery. 2010 RRS, TDV8
Tue Sep 08 2020 7:32pm |
Brill I shall report back tomorrow it makes sense to start there as you say takes guess work out
Tue Sep 08 2020 8:09pm |
Checked this morning battery showing green charged and car fired up no issues again but battery defo lit up still so just waiting on this tester coming now |
Wed Sep 09 2020 7:21am |
