Home > General > No downhill engine breaking?
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Can anyone confirm if the gearbox will slip out of gear when going down a hill (and revs go own to about 750rpm as if idling) by design or is there something wrong with mine?
I live at the top of a long hill and noticed yesterday the car was picking up speed on the decline instead of from what i remember a steady speed controlled by engine breaking. Only noticed it yesterday and of course this morning.
RR ownership has turned me into a nervous wreck waiting for something major to go wrong Confused
Cheers,
Pete. L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
L494 3.0L SDV6 Autobiography MY14 in Chile Red
L320 3.0L SDV6 Autobiography MY10 in Baltic Blue (RIP first RRS love 29/03/2021 insurance total loss)
Post #603977 Tue Sep 01 2020 9:03am
knwatkins
No, it shouldn't do this. It should stay in gear and hold you back if it's in a low enough gear. If you apply the brakes, it will sense you want to maintain a steady speed or slow down and the gearbox will change down accordingly. Kev
Post #603981 Tue Sep 01 2020 11:24am
abiopete
Great Sad
I also get a shunt when coming to a stop as per this thread https://www.rrsport.co.uk/forum/topic56591.html wonder if its related? It started exactly the same time i had a mega flush and reset from a reputable and known Indy.
Any speculation would be appreciated.
Cheers,
Post #603982 Tue Sep 01 2020 11:31am
manually select a lower gear and see if its ok.
Post #603983 Tue Sep 01 2020 12:34pm
abiopete
I'll try manually changing gear later however Its as if the car slips into neutral on its own though so appears not to be in a gear. The revs drop to the resting idle speed of 750rpm coasting at 35mph in D. Even coasting in neutral the revs would normally be at 1100rpm ish? L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
Post #603986 Tue Sep 01 2020 2:40pm
knwatkins
That is weird, Pete. Try lightly braking as you are going down the hill to see if it changes down. Kev
Post #603987 Tue Sep 01 2020 2:59pm
abiopete
Kev
Yeah that was my first instinct, didn't make a difference. Blipped the throttle too to see it was 'out of gear' and that worked fine.
The hill i set off on every morning is about a mile long so there's plenty time for experimenting.
Cheers,
Post #603990 Tue Sep 01 2020 4:59pm
Disco_Mikey
At all times, or only when cold?
Post #603991 Tue Sep 01 2020 5:05pm
abiopete
Only cold it seems, just gone up and down the same hill twice to try to duplicate.
Wonder I’d there’s a mechanism doing it to not put too much of a load on a cold engine? L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
Post #603992 Tue Sep 01 2020 5:53pm
Disco_Mikey
Thats normal. The TC doesn't lock when the temperature of the oil is below a preset value Thumbs Up
Post #603999 Tue Sep 01 2020 7:43pm
abiopete
I love this place, you guys are awesome Bow down
Worrying thing for me, my local 'specialist' suggest i take it round tomorrow for them to have a look at, why doesn't he know?! Rolling with laughter Shocked L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
Post #604000 Tue Sep 01 2020 7:48pm
knwatkins
I thought the box hangs on to the lower gears until the fluid has warmed up, Mike? (ie. to warm it up quicker)
Or is that a different characteristic to what Pete is experiencing? Kev
Post #604001 Tue Sep 01 2020 8:56pm
Disco_Mikey
To an extent
I'll disregard the 8HP box, as it will lock the TC at much lower temperatures, and is a much better gearbox in general Whistle
When cold, the TC does not lock so the engine does not become bogged down in low gears. This is most noticeable when you pull out of a junction, the engine just seems to rev, as the TC is open. When the box is hot, the TC can be regulated to allow a degree of slip, for improved acceleration at slow speeds, and then fully locked for max efficiency
The same happens while slowing down. Because the TC is not locked, the engine speed drops back to idle, and there is very little engine braking. When warm, the TC stays locked, and gives the engine braking effect
Post #604002 Tue Sep 01 2020 9:13pm
knwatkins
Ah, I see. Thanks, as always, for the explanation Thumbs Up Kev
Post #604003 Tue Sep 01 2020 9:26pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Mine seems to do this on occasions when cold, I sometimes wonder if one day it won’t change up Crying or Very sad Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #604004 Tue Sep 01 2020 11:29pm
