![]() | Home > General > No downhill engine breaking? |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 182 ![]() ![]() ![]() |
Can anyone confirm if the gearbox will slip out of gear when going down a hill (and revs go own to about 750rpm as if idling) by design or is there something wrong with mine?
Great |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
manually select a lower gear and see if its ok. |
I'll try manually changing gear later however Its as if the car slips into neutral on its own though so appears not to be in a gear. The revs drop to the resting idle speed of 750rpm coasting at 35mph in D. Even coasting in neutral the revs would normally be at 1100rpm ish? L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
That is weird, Pete. Try lightly braking as you are going down the hill to see if it changes down. Kev
Yeah that was my first instinct, didn't make a difference. Blipped the throttle too to see it was 'out of gear' and that worked fine. The hill i set off on every morning is about a mile long so there's plenty time for experimenting. Cheers, Pete. L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current) L494 3.0L SDV6 Autobiography MY14 in Chile Red L320 3.0L SDV6 Autobiography MY10 in Baltic Blue (RIP first RRS love 29/03/2021 insurance total loss) |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4501 ![]() ![]() ![]() |
At all times, or only when cold? |
Only cold it seems, just gone up and down the same hill twice to try to duplicate.
Thats normal. The TC doesn't lock when the temperature of the oil is below a preset value |
I love this place, you guys are awesome |
I thought the box hangs on to the lower gears until the fluid has warmed up, Mike? (ie. to warm it up quicker)
To an extent
Ah, I see. Thanks, as always, for the explanation |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 316 ![]() ![]() ![]() |
Mine seems to do this on occasions when cold, I sometimes wonder if one day it won’t change up ![]() 2005 2.7 TDV6 HSE, ongoing project. 1998 Volvo V70 R auto FWD, mothballed future project. 1999 BMW Z3 (owned from new) garage queen. |
