| RRSPORT.CO.UK | ||
|  | Home > In Car Electronics > New Android auto 12.1 Tesla for RRS 05-09 |
| Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852      | Result, current home launcher loaded with orange range rover sport as logo 😉🙃
|  Fri Aug 21 2020 6:01pm |
| zeb crs Member Since: 19 Aug 2020 Location: Lillestrøm Posts: 9      | Thank You for the info. I had mine installed today and it was easy to install.
|  Fri Aug 21 2020 6:30pm |
| Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852      | Zeb,
|  Fri Aug 21 2020 6:35pm |
| zeb crs Member Since: 19 Aug 2020 Location: Lillestrøm Posts: 9      | Since it is in my nature to rip stuff apart I managed to wait until today to do it.
|  Sat Aug 22 2020 6:38pm |
| Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852      | So I've had the stereo installed for a few days and thinks it's time to give a small update on what I think. Warning long post, no pictures.
|  Tue Aug 25 2020 6:08am |
| Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303      |
 Do the back doors show as opening on the correct side? My front doors show correctly but the back doors are swapped. If yours work correctly I may ask for some help with your apk files.
 Where did you get your image from to replace? I have been meaning to do this but haven't found a black car image to replace it with. Could you share yours and I will edit it to black please? | ||
|  Tue Aug 25 2020 9:59am |
 How have you done this? I currently have an additional antenna run to the back windows and stuck on there, would love to use the roof antenna instead. | ||
|  Tue Aug 25 2020 10:01am |
 No problem regards the door opening, but, try this first: "Change door setting from left to right (or vice versa), turn off car unlock etc) now all doors will be wrong." Now go back to settings and set drivers door on correct side now doors should work correctly. If that doesn't work,I'll try extract the apk once I get a copy of the software. For the car logo, see post above how to change. How's this (BG removed):   Original:   If you want to do it yourself. Find a photo you like, go to https://www.remove.bg/upload, it will offer a standard res download for free. Then resize to 420x227 place in folder as instructed, long press on the car and hey presto you can select image. Hope that helps. Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" | ||
|  Tue Aug 25 2020 10:18am |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    |
 I think he said hes using an Fakra to SMA male adapter Would that also knock out DAB etc for us ? Also what colour is the GPS antenna's Fakra connector on a 2012 RRS ? | ||
|  Wed Sep 02 2020 6:58am |
| Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303      | I have fakra connectors and splitters. I just don't know where to split it.
|  Wed Sep 02 2020 7:16am |
| Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852      | Gents,
|  Wed Sep 02 2020 8:05am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      |
 I will admit I haven't a clue what you Guys are talking about but I do recall seeing this, also I don't know which Dab band is used but Dab L-Band is in the roof antenna. If it's of no use just ignore me.
   Cheers Col | ||||
|  Wed Sep 02 2020 8:23am |
 maybe im being a complete idiot... But i cant see the Fakra connector on the link. | ||
|  Wed Sep 02 2020 2:52pm |
| Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852      | Nope. No Fakra there.
|  Wed Sep 02 2020 3:07pm |
| Posting Rules
