Home > Technical > Limited gears
Page 2 of 4 <1234>
I guess you need it in neutral
I think you need to remove starter so you have an access hole so you can rotate flywheel and undo bolts holding the TC
Exhaust can be avoided I think.
But you need to remove the crossmember at rear of gearbox. Probably first thing to loosen. Maybe u did this when you did the engine
Post #603163 Tue Aug 11 2020 10:19pm
Download tbe workshop manual. It has the process for gearbox removal. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #603165 Wed Aug 12 2020 12:25am
DerrekL
Ok thanks guys.
I downloaded the manual and reading page 3333 and thereabouts of the manual but don't yet see a reference to what gear it should be in before gearbox removal....
Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #603167 Wed Aug 12 2020 8:02am
well it can't be in Park as you need to rotate the flywheel to undo the bolts thru the starter hole.
So anything other than Park is the answer.
Post #603173 Wed Aug 12 2020 10:30am
DerrekL
Ok thanks Andy makes sense, just like to get these small details sorted out before I start
P38 4.6 HSE V8
Post #603182 Wed Aug 12 2020 11:49am
I can't remember if the electronics (inside the gearbox) is paired to the car.
So you may need to retain your old one to be fitted into the replacement.
It's quite easy to do with the gearbox fitted to the car (as long as it has the metal sump that is)
Post #603183 Wed Aug 12 2020 12:00pm
DerrekL
When I leave in neutral I cannot remove the key from ignition, not saying that's an issue as I'll be disconnecting the batterry, but that's ok , correct ?
Only other thing I'm a bit confused about is if I'm dropping the gearbox as one lump then why do I need to move the flywheel, what I mean is I thought the TC was internal part of the gearbox ? RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #603184 Wed Aug 12 2020 12:11pm
Yeah that is correct.
The flywheel (engine) is bolted to the torque convertor.
Probably need to look at some videos
Post #603185 Wed Aug 12 2020 12:26pm
Watch at 5 mins and 14 mins.
Exhaust and prop is different. Some is the same.
Think of the access hole as the starter and crank locking tool hole
There is a lot less room in BMW’s so you shouldn't need to remove so much, or tilt the gearbox
Post #603186 Wed Aug 12 2020 12:33pm
Disco_Mikey
The engine will turn with the gearbox in Park...
Post #603187 Wed Aug 12 2020 12:45pm
The important thing on the diesels is to remember to unbolt the exhaust cross over pipe bracket.
These are very expensive. Also remember to re fit. Awkward but necessary
Post #603188 Wed Aug 12 2020 1:04pm
DerrekL
Stuck at trying to get the bolts out of the front section of the front prop shaft. Thought I could turn this by hand but it's like it's stuck in a gear. Otherwise seems impossible to get to the two remaining bolts at the top of propshaft. Any ideas ?
P38 4.6 HSE V8
Post #603199 Wed Aug 12 2020 5:46pm
Started already Laughing thought that vid had put u off.
Take it out of park or if that don’t work lift at least one front wheel
Post #603201 Wed Aug 12 2020 6:09pm
DerrekL
Yes neck deep now, no turning back Censored
It was in neutral before I started and now cannot lift the wheels as they are all strapped to the ramps.
I've also tried clicking the gear selector from underneath but that didn't release the prop shaft either any other method to get round this ?
P38 4.6 HSE V8
Post #603207 Wed Aug 12 2020 7:30pm
No. You must lift one wheel
Post #603208 Wed Aug 12 2020 7:41pm
Page 2 of 4 <1234>
