![]() | Home > Technical > Limited gears |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9092 ![]() ![]() ![]() |
Download tbe workshop manual. It has the process for gearbox removal. |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Ok thanks guys.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5099 ![]() ![]() ![]() |
well it can't be in Park as you need to rotate the flywheel to undo the bolts thru the starter hole.
Ok thanks Andy makes sense, just like to get these small details sorted out before I start
I can't remember if the electronics (inside the gearbox) is paired to the car.
When I leave in neutral I cannot remove the key from ignition, not saying that's an issue as I'll be disconnecting the batterry, but that's ok , correct ?
Yeah that is correct.
Watch at 5 mins and 14 mins.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4508 ![]() ![]() ![]() |
The engine will turn with the gearbox in Park... |
The important thing on the diesels is to remember to unbolt the exhaust cross over pipe bracket.
Stuck at trying to get the bolts out of the front section of the front prop shaft. Thought I could turn this by hand but it's like it's stuck in a gear. Otherwise seems impossible to get to the two remaining bolts at the top of propshaft. Any ideas ?
Started already |
Yes neck deep now, no turning back |
No. You must lift one wheel |
