Home > General > L494 MY2014 Autobiography - Unused connector
Heremyjill
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hello from a RRS newbie,
I am slowly discovering new things about my RRS Autobiography as I have now enjoyed its presence for about two weeks and have discovered this connector underneath the dash on the driver's side and near the accelerator.
I thought that the car had nearly everything specified on it and ask if any of you RRS experts out there can advise what the connector may fit to and is it something I can buy and get retro fitted?
Post #601164 Thu Jul 02 2020 4:16pm
Brit Plumber
You need to post a photo of it. It could be that it’s popped off something or what I’m thinking is, that someone may have removed the lower trim panel with the footwell light and that’s the light connector. Is it a 2 wire position plug? Do you have a foot well light? I’m suspicious as you shouldn’t normally see anything because the panel covers it all. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #601199 Fri Jul 03 2020 9:14am
The photo is in the OP's gallery:
 2012 SDV6 - it's missing a couple of cylinders
Post #601200 Fri Jul 03 2020 9:29am
Heremyjill
Here is a photo with the lower dashboard in place
Post #601206 Fri Jul 03 2020 10:44am
Do they fit a transport relay somewhere when they're on the transporter trucks? Might this be where it's plugged in? 2012 SDV6 - it's missing a couple of cylinders
Post #601212 Fri Jul 03 2020 12:03pm
thats usually under the bonnet.
thick wires whatever it is
Post #601215 Fri Jul 03 2020 12:35pm
Brit Plumber
That has some hefty wire going to it! 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #601216 Fri Jul 03 2020 12:38pm
idi
Touch the pins together with a screwdriver, see what fuse goes and then you'll know Laughing
Post #601255 Fri Jul 03 2020 11:04pm
Heremyjill
Thank you and yes that is a good idea about the fuse. I am not sure how I would easily find out which fuse has blown though.
Post #601417 Wed Jul 08 2020 8:54am
I think that was mostly a joke suggestion Laughing
Post #601423 Wed Jul 08 2020 11:25am
Heremyjill
Not getting too much luck with this question. How about I phrase it differently?
Can all of you fellow members out there that have a RRS MY2014 3.0 SDV6 Autobiography have a look at the lower dashboard on the driver's side and let me know if you have any electronic interfaces that are sited around the accelerator pedal?
The resulting list should then give me an idea of what is missing from my car and what this connector could be used for
Thank you
Post #602125 Fri Jul 24 2020 4:59pm
Heremyjill
A highly probable use for this connector has been found. Thank you to PJBracer1
It looks like this model AB has the wiring already installed for a set of retractable Side Steps. If this option had been fitted, the switch would have been one of two by the driver's knee. (the other would be the electronic hatchback opening switch). This switch would have then been in close proximity to where this connector can reach.
Thank you to all "Every Day is a School Day"
Now 2014MY RRS SDV6 AB
Now 2018MY Ford Fiesta ST Line 140bhp
Gone 2006MY BMW X5 3.0d Le Mans
Gone 2001MY BMW 530d Estate
Post #603323 Sat Aug 15 2020 12:18pm
