![]() | Home > In Car Electronics > New Android 9 Discovery/RRS Android Stereo System |
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
Thank you |
Luke, just a thought, if you want a factory look for the USB, you could get a late Disco 4 top glove box with the USB input, I’ve put one in mine and it just needed a locating tab trimming off the Disco 4 version for it to fit.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Ok played around a little more today .
After some more playing :
Just to add, Apparently this is a software "Issue".
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Luke,
I have had a few android units before , Never had them get hot enough to reboot loop :p
I've had a few different units some did overheat and shutdown, however, the Joying unit has performed well on that count, even with 40C heat here. It helps that the actual HU is nestled between the AC vents deep inside the dash.
OK installed their update today and the unit is sitting around 68-70c , This is with 2 map software's and their audio software playing. ( 20-30% load )
OK Onboard microphone. Something is definitely not working correctly with it . They also don't provide an external Aux connector for an external Mic.
Good news on the mic. Will you mount it in the interior light housing? Kev
Unsure as of yet , Need to find out my options on the USB microphone really.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
someone on youtube has fitted an android unit to a discovery. They said the internal mic was useless, and you should get one with an external mic input |
To be fair my GF's bmw one is fine .
