Home > General > Oil filler cap removal
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. I'm in the middle of a home service - first time, usually its serviced by my local garage in France. I don't seem to be able to remove the Oil Cap on the top of the engine?? When I twist it, it moves at an angle as though its been cross threaded! I presume it should simple unscrews with a ANTI CLOCK-WISE turn and lift off. Grateful for advice Andrew Kennedy
Post #599821 Sun Jun 07 2020 12:24pm
Tyrefitter
Hi,put a screwdriver under the cap when you have unscrewed it anti clockwise as it may just be stuck on if it hasn’t been off in a while. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #599824 Sun Jun 07 2020 1:35pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Mine is very stiff but just get a pair of grips on it turn and lift - you really cant do any damage
Post #599825 Sun Jun 07 2020 1:38pm
andrew kennedy
PROBLEM SOLVED Andrew Kennedy
Post #599827 Sun Jun 07 2020 2:24pm
andrew kennedy
NOT THE END OF THE PROBLEM........I had difficulty unscrewing the Oil Filler Cap because the last person had over tightened it!! Now the problem is the pipe the cap fits onto (pipe coming up from the engine) is loose!!!! THAT CANT BE RIGHT. I'm wondering how the pipe is secured? and what can I do about making it secure?!? Andrew Kennedy
Post #599870 Mon Jun 08 2020 11:26am
I don’t recall a pipe
You got a picture?
Post #599871 Mon Jun 08 2020 11:27am
Could he mean dipstick tube.
Post #599876 Mon Jun 08 2020 11:50am
andrew kennedy
Thanks for coming back Andy!! Not to computer savvy re putting up pictures. Its the short plastic tube section with a thread that cap thread fits into. Some how its become unattached to the top of the engine! It doesn't come complete out, its just loose. After putting the oil cap back on, with a little more pressure, the lot turns. Andrew Kennedy
Post #599877 Mon Jun 08 2020 11:54am
andrew kennedy
No not the dipstick tube......Its the short section of tube on top on the engine that the Oil Cap screws onto. When screwing down the oil filler cap, with a little added pressure the hole lot turns. Andrew Kennedy
Post #599879 Mon Jun 08 2020 12:01pm
do you see it in this pic ?
https://www.ebay.co.uk/itm/Land-Rover-Disc...SwtLterYn~
Post #599886 Mon Jun 08 2020 3:51pm
andrew kennedy
Thanks for staying with me Andy. I'm rubbish as this.....no not on the web page you suggested. This is the part number for another model but the same item as I am talking about Rover Discovery 3 4 5 Range Rover Oil Filler Cap Genuine LR053016 The problem is when I screw the cap down, the piece of tube its screwed to (which is attached to the top of the engine) moves half a turn. Obviously it shouldn't - it should simple be a quarter spin of the cap to lock it down - end of story. Hope that explains what I am trying to get over. Andrew Kennedy
Post #599889 Mon Jun 08 2020 5:45pm
Oh. The oil cap Laughing
As you say should be a brief twist. Don’t know how the tube worksm
Post #599893 Mon Jun 08 2020 7:43pm
andrew kennedy
Tricky one isn't it. I guess I need to know how it should be secured and what I can do about it. I think I will be lucky if any one comes back with an answer. As the connection is not good, I wonder if I am likely to loose necessary pressure in the oil system. Thanks for all the help Andy!! Kind regards from a very windy and rainy Brittany. PS I don't like it when the car is not working as it should, I've had it since new and its only done 85,000 miles and in generally good nick.  Andrew Kennedy
Post #599896 Mon Jun 08 2020 8:08pm
I don’t think it’s a big issue to worry about.
Post #599901 Mon Jun 08 2020 9:49pm
Looks like it might just turn and lock in unless the picture is just the cap bit only it's listed as pipe and cap, may just need new 'O' ring to tighten up unless a lug of some sort is broken.
Post #599902 Mon Jun 08 2020 10:14pm
