Home > General > Oil filler cap removal
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Thanks for that Col!! It looks to me as though the pipe section should twist and detach from the engine? What do you think? As mine is loose I don't like to play around with it just in case its damaged in some way. The wording of your post indicates to me you are just showing me a pictures of the two parts and perhaps you haven't had the need to remove or replace the pipe yourself? Andrew Kennedy
Post #600172 Sat Jun 13 2020 8:32am
Andrew, that picture is based on L/R's part number and I think it shows the cap and pipe as a pair as that is how they sell it, I haven't actualy had to replace one as I have the s/c which is different. Google 1336599, LR016955 or LR037844 should bring up various pictures.
Post #600173 Sat Jun 13 2020 8:40am
andrew kennedy
Col wrote:
Looks like it might just turn and lock in unless the picture is just the cap bit only it's listed as pipe and cap, may just need new 'O' ring to tighten up unless a lug of some sort is broken.
Yep, looks as though the '0' rings needs replacing - I can't think I am going to be able to buy just the '0' ring? so got any suggestions as to what material I can use to put round the pipe before tightening it down?!?! Andrew Kennedy
Post #600224 Sun Jun 14 2020 9:24am
You can actualy buy "O" rings if you were to measure it you could possibly get one from a plant hire firm or hydraulic specialist or you can actualy buy kits to make your own.
Post #600226 Sun Jun 14 2020 9:36am
andrew kennedy
Just about everything is closed down over here in Brittany and I don't fancy my chances of finding a 45mm ID '0' ring Would you know, by chance, of a RR Spares supplier in UK that might be worth contacting for such a small order?!? Andrew Kennedy
Post #600235 Sun Jun 14 2020 2:27pm
Would it not be easier just to order a new cap/pipe from someone like Advanced Factors, they deliver to me in N/Z so sure they would deliver to France, in addition if the part has been damaged at all due to overtightening it would solve the problem.
Post #600260 Sun Jun 14 2020 9:23pm
