Home > Technical > suspension troubles |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
Was it a sub £200 one from Ebay? |
Tue Apr 07 2020 6:30pm |
markg103 Member Since: 06 Apr 2020 Location: cambridge Posts: 35 |
Hi Yes it was a cheap £125
Tue Apr 07 2020 6:34pm |
Hi all still trying to figure out whats wrong , so i have taken the compressor of the car connected it direct to the battery and it runs fine its sucking and pushing air in and out but when on the car it runs for 5 seconds then cuts out and amber light comes on, the car is on the bumps now but took about 10 days so i am guessing its holding air reasonably OK, if i connect the pump direct to battery when on the car in order to pump the suspension up would it work or could i cause more damage.
Mon Apr 20 2020 5:06pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
I believe ppl have done this before
Mon Apr 20 2020 6:24pm |
Many thanks for the reply i was wondering if i could put enough air into the system to drive to a garage if needs be or just to see if it would raise the vehicle thus eliminating the pump if the vehicle would raise, at the moment i am looking for leaks valve blocks etc but not sure if the pump would only run for a few seconds as i does if its just a leak.
Mon Apr 20 2020 6:57pm |
swatkins Member Since: 01 Apr 2017 Location: Essex Posts: 56 |
Been through all of this brought the £125 only then the £175 one then then £180 from ebay all sent back and refunded without question, buy this one it works https://www.lrparts.net/lr023964-air-suspe...relay.html
Mon Apr 20 2020 8:39pm |
Hi thanks for the reply i was thinking it a faulty compressor but it works connecting it direct to battery thats what confusing me i assumed if it works directly it must be ok, but thanks il take a look.
Mon Apr 20 2020 8:43pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I also have a Dunlop compressor and it's been very reliable since I installed it.
Mon Apr 20 2020 9:34pm |
Thanks guys happy to buy another compressor just trying to clarify that is the problem
Mon Apr 20 2020 10:02pm |
Hi Guys
Sat Apr 25 2020 12:27pm |
Disconnect battery for at least 30 mins |
Sat Apr 25 2020 1:10pm |
OK many thanks
Sat Apr 25 2020 1:27pm |
Hi guys finally got the car running and run a scan, the code it gave is C1131 low air supply can anyone suggest anything other than a compressor before i purchase another one, the compressor runs for a about 5 seconds then the light comes on.
Sat Apr 25 2020 4:40pm |
Hi all can anyone tell me if if the GAP tool is the only tool that can you can purchase to setup ride height as fitted new a sensor and the suspension is all over the place.
Wed May 06 2020 7:42pm |
