Home > Technical > suspension troubles
markg103
United Kingdom 2006 Range Rover Sport TDV6 HSE Lux Santorini Black
suspension troubles
Hi Guys i have just fitted a new Hitachi compressor, when i start the car it runs for about 5 seconds and stops but car is on the stops and wont raise, could it be a faulty compressor or something else.
Regards mark
Post #597486 Tue Apr 07 2020 6:23pm
Disco_Mikey
Was it a sub £200 one from Ebay?
Post #597487 Tue Apr 07 2020 6:30pm
markg103
Hi Yes it was a cheap £125
Regards mark
Post #597488 Tue Apr 07 2020 6:34pm
markg103
Hi all still trying to figure out whats wrong , so i have taken the compressor of the car connected it direct to the battery and it runs fine its sucking and pushing air in and out but when on the car it runs for 5 seconds then cuts out and amber light comes on, the car is on the bumps now but took about 10 days so i am guessing its holding air reasonably OK, if i connect the pump direct to battery when on the car in order to pump the suspension up would it work or could i cause more damage.
Regards mark
Post #597932 Mon Apr 20 2020 5:06pm
I believe ppl have done this before
But you are playing with fire if u run the pump for more than 30 seconds at a time
Ensure all doors are closed if u do.
I assume the sensors on the cheap pump are not up to scratch
Post #597934 Mon Apr 20 2020 6:24pm
markg103
Many thanks for the reply i was wondering if i could put enough air into the system to drive to a garage if needs be or just to see if it would raise the vehicle thus eliminating the pump if the vehicle would raise, at the moment i am looking for leaks valve blocks etc but not sure if the pump would only run for a few seconds as i does if its just a leak.
Regards mark
Post #597936 Mon Apr 20 2020 6:57pm
swatkins
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
cheap compressor
Been through all of this brought the £125 only then the £175 one then then £180 from ebay all sent back and refunded without question, buy this one it works https://www.lrparts.net/lr023964-air-suspe...relay.html
Poor mechanic fitted 3 before this one worked properly.
Post #597944 Mon Apr 20 2020 8:39pm
markg103
Hi thanks for the reply i was thinking it a faulty compressor but it works connecting it direct to battery thats what confusing me i assumed if it works directly it must be ok, but thanks il take a look.
Regards mark
Post #597945 Mon Apr 20 2020 8:43pm
knwatkins
I also have a Dunlop compressor and it's been very reliable since I installed it.
The link above is a very good price also! They are usually over £300 inc VAT. Kev
Post #597951 Mon Apr 20 2020 9:34pm
markg103
Thanks guys happy to buy another compressor just trying to clarify that is the problem
Regards mark
Post #597952 Mon Apr 20 2020 10:02pm
markg103
Hi Guys
Help needed please, since posting i decided to order the icarsoft v11 , i connected to the vehicle and click run a scan i came back check link as not connected, but it is connected and since then the vehicle ignition lights wont even come on its worse than ever any ideas guys
Regards mark
Post #598119 Sat Apr 25 2020 12:27pm
Disconnect battery for at least 30 mins
Post #598121 Sat Apr 25 2020 1:10pm
markg103
OK many thanks
Mark
Post #598126 Sat Apr 25 2020 1:27pm
markg103
Hi guys finally got the car running and run a scan, the code it gave is C1131 low air supply can anyone suggest anything other than a compressor before i purchase another one, the compressor runs for a about 5 seconds then the light comes on.
Regards mark
Post #598133 Sat Apr 25 2020 4:40pm
markg103
Hi all can anyone tell me if if the GAP tool is the only tool that can you can purchase to setup ride height as fitted new a sensor and the suspension is all over the place.
Regards mark
Post #598633 Wed May 06 2020 7:42pm
