Home > Technical > suspension troubles |
markg103 Member Since: 06 Apr 2020 Location: cambridge Posts: 35 |
Hi thanks for that i didn't realise there was a filter under there i will check it out many thanks
Fri May 08 2020 8:17pm |
Hi Lazysteve. i see the filter from a diagram before i get under the car is it a filter you clean or just order new filter with pipes
Sat May 09 2020 7:34pm |
Morning all. well after fixing various problems the car is running perfect well until last night , i drove a mile up the road and heard a loud bang the suspension hasn't dropped but the pipe coming from the Drier had popped out i have pushed it in and feels ok but i was wondering do i have a bad fitting connection or do i have a blockage somewhere that can cause it to build up pressure forcing the pipe out.
Tue May 26 2020 9:29am |
lazysteve Member Since: 17 Dec 2011 Location: Bulgaria, Nessebar Posts: 13 |
I had mine changed by the garage as the engine blew up during the time I was having the suspension problems and the body was off so they changed it. It looks like a really difficult place to get to. I had them put a new filter on as I didn't want to have to do it again. |
Tue May 26 2020 7:38pm |
Thanks Steve, Changed to filter now car just about runs perfect.
Tue May 26 2020 8:02pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Are you talking about the filter inside the vehicle behind the nearside boot trim? Kev
Wed May 27 2020 10:57pm |
Yes, under the chassis in the back seat area. Never managed to see it until the body was off the car for the engine swap. |
Thu May 28 2020 10:21am |
Thanks Steve all finally sort out now
Thu May 28 2020 11:35am |
