![]() | Home > Technical > Front and rear polyurethane swaybar bushings |
Any difference in ride quality? Kev
turbostang Member Since: 21 Dec 2012 Location: New York Posts: 10 ![]() ![]() |
The ride quality feel firm. Less body roll. And no more squeak. 2008 Range Rover Sport S/C |
The only thing that would concern me is the attraction of dirt causing premature ware to the material. 2019 5.0 SC SVA (Current)
Polyurethane bushing suppose to last a lot longer than the oem rubber bushing . 2008 Range Rover Sport S/C |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
"Polyurethane bushing suppose to last a lot longer than the oem rubber bushing."
All 3 pair of sway bar bushings was replaced with oem lr bushing by the LR dealer. The reason the bushing was replaced, the annoying squeak and knock going over uneven road surfaces. I spray silicone lubricant to quiet it down, but it was only temporary. The bushings seem last about 20 to 30k miles. Currently mileage 100450.
mermade Member Since: 09 Jan 2019 Location: manchester Posts: 2 ![]() ![]() |
It depends on the quality of the poly bushes... companies like powerflex offer a lifetime guarantee on them.
Aftermarket suppliers make many claims and these are not necessarily true. I know if Indys and private owners alike that have had bad experiences of short service life, and stick to branded OE as a result. This includes the high profile ones.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Powerflex front ARBs here fitted about 2 years ago and 20,000 miles. Since then no squeaking or knocking from the front at all. Prior to that, I was going through ARBs/the pain every 10-15k miles. Driving is a lot of country road, fields and some off-roading. Is it firmer? Probably but nothing that I think impacts ride quality.
A follow up for the poly bushings for the front and rear sway bars
Great news. Thanks for reporting back |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 223 ![]() ![]() ![]() |
Mine had polyurethane when I purchased it , they were all removed by my indie when it went in for repairs & a service he doesn't recommend them at all, OE ones now on vehicle. |
Hey Boxer, why were your bushing replaced? Squeaking?
Hi Turbostang, I simply bought the RR & searched for an indie by recommendation found a really good one and told him to put right everything he thought needed doing so went with his knowledge & experience, the vehicle did have some rattling from the front when going over speed humps this has all been eliminated now. Goes back in August for its MOT test when the front discs & pads will be replaced. |
