![]() | Home > General (L494) > 18, 19 SVR owners, question |
| the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577
Hi guys,
| SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1828
| Netsters Member Since: 07 Nov 2011 Location: London Posts: 175
Would be great if it was just a software update as means could have it sorted while I wait. Would make sense to be software as I noticed the valves are open on a cold start, which might point to a front panel software issue. Btw what other issues was you car in for? A Range Rover Sport SVR - Santorini Black Range Rover Sport Autobiography 2016 Yulong White / black interior - Stealth pack Ferrari 360 F1 Spider red/cream Ferrari 348 ts red/cream BMW M4 Convertible Competion Pack |
| Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 262
The software update must open the valves at a lower RPM I don’t know what else could cause the sound to change. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
| nil07 Member Since: 05 Apr 2015 Location: london Posts: 115
For the pops I have noticed they can also occur on conform or auto terrain mode.
| Santy72 Member Since: 05 Feb 2020 Location: Cheshire Posts: 3
@Netsters, thanks for this post. I'm CONVINCED i have the same problem. Some days my 2018 SVR sounds mega (almost as good as my previous 2017 pre face lift car) other days the sports button makes literally NO DIFFERENCE whatsoever!!! I've almost reached the point where I've considerd getting back into an AMG as the engine note is a big part of the appeal of an SVR for me. What did error correction entail when the LR dealer did admit you had a problem? Was it a software rebuild or parts replacement? Cheers John |
Other change is by replacing the GPF exhaust section with an X Pipe. Just not sure if this invalidates the LR Warranty?
Hi Guys,
Hi There
Sure, "Custom Chrome" in Nuneaton near me. The plan is that one side of the silencer is clamps on to the down pipes and other side are straight. Undo off clamps, cut say 100mm from silencer. Replicate with straight pipes and modify the silencer to have larger sleeve welded on to go back over the original pipes. 2018 SVR |
This may help visualize, I assume the blue is the resonator? And red is the particulate filter?
Nearly, red is centre silencer, blue is resonator.
Just got my car back from the dealers today. it had the software update overhaul. I haven't had a chance to speak with the technicians yet to see exactly what they did, allow they did mention that they lubricated the values. I do notice a slight change when pressing the active switch button, so the console is at least working, however when shining a torch down the exhaust pipe, it looks like the value is only slightly open, not fully open as I was expecting. I am due to have a fuller chat with them this week to see if the back boxes need replacing altogether, but can I ask if anyone would be prepared to post a picture of their exhaust with the value open, so I can see what position a functioning valve should be in. txs Range Rover Sport SVR - Santorini Black Range Rover Sport Autobiography 2016 Yulong White / black interior - Stealth pack Ferrari 360 F1 Spider red/cream Ferrari 348 ts red/cream BMW M4 Convertible Competion Pack |
Sure, happy too. When.would you like the pic? I mean car fully warmed up after a run, at idle, auto terrain mode, active exhaust on etc? 2018 SVR |
| All times are GMT |
