Home > General (L494) > RFID (Faraday) Pouch - Failures
RRT
Since May I have been using RFID pouches to help protect my RRS against relay attacks. However I have found that after about 8 to 10 weeks the pouch has failed and I am able to open the doors and start the engine with the keys in the pouch. I have now had 2 pouches (different makes but cheap ones from Amazon) fail. Anyone else having this problem? MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #589154 Thu Oct 24 2019 7:29am
Tyrefitter
I bought 2 from amazon & both are still working fine,i always have one in my pocket at work as sometimes ive caught the boot remote by mistake & had customers come in my place to tell me my boot is open so I know keep them in my pocket in a pouch & I know it works as when I finish work I sometimes forget to remove key & car wont open. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #589156 Thu Oct 24 2019 7:37am
MrM
Could you not disable keyless entry and then you don’t have to worry?
Post #589163 Thu Oct 24 2019 9:44am
scarey
i've disabled mine and can sleep peacefully now Thumbs Up
Post #589167 Thu Oct 24 2019 12:26pm
RRT
I have ordered another one of a different brand. I put a good bunch of keys inside the pouch and maybe it is wearing away a metallic coat.
The warning here is - don't expect the RFID pouch to last. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #589169 Thu Oct 24 2019 12:34pm
Tim in Scotland
The other thing to watch out for is that in some of them only one side of the Faraday mesh liner is sewn to the wallet and it is very easy to slip the keys between the mesh and the plastic wallet. The pouches I bought off Amazon it is very easy to think you you have put it in correctly but in fact you haven’t actually put it inside the mesh part of the pouch.
 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #589171 Thu Oct 24 2019 2:26pm
RRT
UPDATE
Third (different syle) has now failed.
I had now tried 3 different pouches in 8 months and they have all failed. With the latest pouch I have only put the car key in it rather than the full bunch of keys.
BASED ON MY EXPERIENCE - YOU CAN NOT TRUST RFID POUCHES! MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #593052 Thu Jan 09 2020 12:37pm
chi
Same for me . Two pouches failed after about 8 weeks use.
Now have disabled keyless entry.
Feels much safer Smile
Post #593053 Thu Jan 09 2020 12:54pm
Ash3
Ditto...I use pouch and it still works...but disabled keyless entry too...just in case Wink
Post #593055 Thu Jan 09 2020 2:00pm
Aguiness
Hi I’m not sure how a pouch can fail, the pouch has a material woven into it to stop the signal getting out and in
This won’t fail I think what you mean is damaged due to wear
I would try to get a more robust pouch that you won’t damage as easily
Post #593060 Thu Jan 09 2020 5:03pm
louischristie8
2005 Range Rover Sport Supercharged Java Black
Is it 100% confirmed that disabling the keyless entry removes the theft / break in threat?
Post #593063 Thu Jan 09 2020 6:15pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
How do you disable keyless entry ?
Post #593064 Thu Jan 09 2020 6:17pm
ilard
If you disable keyless then you have to use the remote’s buttons. When you use the remote’s buttons you are transmitting a signal that can be intercepted and recorded for playback, thus opening your car. I have a friend who lost their Q5 in this manner from a multi-storey car park. So disabling-keyless approach may or may not present a better risk profile than using keyless depending on your circumstances and your luck. I am referring to prior to MY18, because from then on I understand JLR security got a bit more sexy.
I have not yet had a pouch fail myself. When at home a metal biscuit tin or aluminium foil is an alternative to a manufactured pouch. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #593076 Thu Jan 09 2020 10:08pm
knwatkins
I use a little tin to keep my keys in. In addition, it's no where near the front door. Kev
Post #593078 Thu Jan 09 2020 10:16pm
HaggisMan
If you use a metal box (as I do) make sure there are no holes/gaps whatsoever. I initially bought a key safe but because of the tiny gaps around the hinge it didn’t work. A cheap metal tin with a tight fitting lid works a treat and although in have a 2019MY car with the more advanced security, I still keep the keys in the box at all times when I’m not driving it.
Post #593083 Thu Jan 09 2020 10:36pm
