Home > General (L494) > Warranty Knock Back - Dynamic Suspension Failure 2014 L494
PauloAmore
Scotland
Pipe assembly valve block leak in 2014 Dynamic suspension....
Warranty knocked back on the basis that the pipes have corroded.... Corrosion is not covered... £2,500
Thing is, the pipe is a little corroded (as pictured), but its more like the connection piece. The mechanic suggests replacing the whole pipe run from the reservoir to the ARB cylinder.
Thoughts? Help! Suggestions appreciated. Having just spent £850 on a warranty extension (I kinda thought i was covered).
Edit : Odd - corrosion is not excluded from the policy.
https://landrover-extendedwarranty-extend-...cument.pdf
My plan? MOT it. It will fail. Then they fix it under warranty?
Corrosion is mentioned 3 times in the policy documents.
Page 27 : MOT Insurance
- Corrosion is INCLUDED
Steering and Suspension Manual and power steering units, operation of steering lock (where fitted), drag links, track rods/ends, transmission shafts, Constant Velocity (CV) joints and boots, shock absorbers, road springs, wishbones, anti-roll bar links, swivel joints, mountings and bushes, sub-frames and wheel bearings are covered for failure due to: Wear, seizure, leakage, and insecurity. Steering wheel for cracks or fractures.
Peter Vardy Aberdeen - love it. 2022 P440e AB
Post #585383 Thu Aug 15 2019 5:41pm
DrRob
Get a lawyer onto it. Big hammer straight away Thumbs Up * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #585386 Thu Aug 15 2019 6:01pm
ilard
Seriously, the level of cover vs price is so poor compared to Warranty Direct (and probably other providers) that include wear n tear and such. So I don't know why people buy the LR warranty, I must be missing something.
If a good moan doesn't resolve then potentially pursuing a mis-selling route is an option, or at least the threat of it, for example if in the sales process you were led to believe all was covered. Not sure about Scottish law, but consumers are not expected to read & understand every word of a multi-page terms & conditions document in many circumstances.
Very disappointing situation, sorry you are going through this. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #585391 Thu Aug 15 2019 8:44pm
Farmer Chalk
I had this argument with the Approved used warranty over my rear aircon pipes on my G4 D3.... I failed .... and since I have refused to renew with them..
Same argument....corrosion.... they are Censored !
Post #585397 Thu Aug 15 2019 9:57pm
They are a third party insurance company so expect them to do what they can to not pay.
Claiming "corrosion" is a bit off, however, for anything thst hangs in the elements under the car. It will have some corrosion on it within months of leaving the factory.
Talk to the ombudsman if the warranty won't budge. Unfair terms get the ombudsman's back up. 2012 SDV6 - it's missing a couple of cylinders
Post #585407 Fri Aug 16 2019 8:33am
PauloAmore
Scotland
Thanks chaps...
Interesting its a £2,5k repair at a land rover dealer and £1.2k at my local indie.
Trusted indie (Strathearn Engineering) reckons the pipes can and do corrode / leak (therefore perhaps not just the connections). Amazes me one could fit pipes that corrode in less than 5 years to leak through the metal of the pipe.
Might be interesting to have a thread on warranty claim knock backs. 2022 P440e AB
Post #585415 Fri Aug 16 2019 4:46pm
Disco_Mikey
Sent cars back under warranty for brake pipe and ARC pipe leaks. They seem to have made them even worse than the previous generation model Rolling Eyes
Post #585424 Fri Aug 16 2019 7:49pm
PauloAmore
Scotland
40% goodwill offered from JLR. Original quote £2500.
- to replace the corroded ARC pipes on the dynamic system. On a LR Extended warranty that includes no such exclusion.
Can’t say I’m impressed. 2022 P440e AB
Post #585680 Wed Aug 21 2019 8:17pm
Raven8080
I've got a RRS 2014, with extended LR warranty, suspension fault light came on at weekend. I've taken it local LR garage and they have advised pipes are corroded and quoting £2.5k to repair plus VAT.
They've said it's not covered under extended warranty.
Post #590968 Mon Nov 25 2019 3:36pm
Tyrefitter
Ive just replaced rear brake pipes on my15,they were also corroded,ive seen better brake pipes on 15 year old corsa's ect. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #590969 Mon Nov 25 2019 3:47pm
Raven8080
only had the car a year, so the car comes with the 2 year LR warranty, was told it covers pretty much everything apart from the normal wear and tear, such as brakes, tyres etc. I wouldn't have expected a 5 year old car having this issue
Post #590971 Mon Nov 25 2019 3:54pm
Tyrefitter
My brake pipes are covered under MoT warranty but didn't want to risk them till march when MoT is due so I replaced them myself. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #590972 Mon Nov 25 2019 3:56pm
PauloAmore
Scotland
Same for me. Get LR to do a goodwill jesture. And we’ll do a joint complaint to the ombudsman.
Nothing in the documentation excludes corrosion.
Take it for an mot. There’s 700 right there for failure. I threatened that before I got the goodwill. 2022 P440e AB
Post #590973 Mon Nov 25 2019 4:01pm
Raven8080
happy to do a joint complaint. I'll pm you my details.
I'm at work, so haven't had a look at the paperwork, but I assume the 2 year warranty that came from LR will be the same at their extended warranty.
Post #590974 Mon Nov 25 2019 4:05pm
Imac819
I see people say take the car for an MOt for the corroded ACE system pipes due to warranty not covering them. Why is this?
Post #640817 Sat Mar 30 2024 1:43pm
