Home > General > 2012 sport no power on passenger side
Page 3 of 5 <12345>
Brit Plumber
That’s the right one. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587675 Fri Sep 27 2019 9:54pm
Steven 17
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Fuji White
Dam thing just dosent work
Post #587676 Fri Sep 27 2019 10:01pm
Steven 17
Would the driver side one be different?as I could try swapping them if they are the same
Post #587679 Fri Sep 27 2019 10:10pm
Brit Plumber
The drivers side module is different with pt number BH42-14D618-AA.
I PMd you earlier. 2019 5.0 SC SVA (Current)
Post #587681 Fri Sep 27 2019 10:30pm
Steven 17
Ow man made it one digit different just to confuse things ha ha
Post #587683 Fri Sep 27 2019 11:03pm
Still really puzzling if nothing works on rear door as well, as rear door module on different circuit, fuse 39 and front 30 unless all linked to central locking somehow.
Post #587684 Fri Sep 27 2019 11:36pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
As you measured power going to door module, just throwing these earth diagrams in, not sure they are 100% the same on a 2012 but bet it's fairly similar.
I know you said you measured earth/ground on indicator, but if you could check the motors and solenoids for both positive and ground when activated, you'll be wiser to what's missing.
Under the carpet is some earth splices there will corrode when exposed to water/dampness.
Up with carpet, likely need to take out passenger seat first, bunch of wires need unwrapped a bit and you may find connections corroded away, needs re soldered together and protected.
Post #587685 Sat Sep 28 2019 12:18am
Brit Plumber
It’s a little different for the later cars, all the earths run to the door module and then a larger earth runs to a stud at the base of the A pillar. 2019 5.0 SC SVA (Current)
Post #587691 Sat Sep 28 2019 8:47am
Steven 17
I’ll have a go with the multi meter today if I get chance.are all black wires ground or will some be power too?
Post #587692 Sat Sep 28 2019 9:03am
Brit Plumber
I think some black are power. 2019 5.0 SC SVA (Current)
Post #587693 Sat Sep 28 2019 9:22am
Brit Plumber
Did you say if your speakers are working on the doors?
Are you getting exactly the same issues as you were with the original door module? 2019 5.0 SC SVA (Current)
Post #587694 Sat Sep 28 2019 9:23am
Steven 17
Well when I purchased the car everything was working apart from the door locks on passenger side.when I noticed the door locks wasn’t working a couple of days later I stripped the passenger front lock out to take a look at it.i took the cover off to reveal just 2 motors in the lock.i took the motors out to see if I could find a part number then re fitted them.i put the lock back in as I couldn’t get a replacement the same day.put everything back together and it all worked again apart from the locks on passenger front and back.i purchased new locks for front and rear but before getting chance to fit them I noticed nothing was working then.so I did a google search and it came up with a blown door module so I ordered a direct replacement.when it arrived I plugged it in and I got power to the windows on their own switches on the door but nothing would work from the main switch on the drivers side then after like a minute or two they would stop working.since removing the original module thow I’ve not had the power mirrors work at all.ive fitted new locks to both doors but they won’t lock either.ilve not chef to see if I’m getting sound from the speakers I’ll check that later on and let you know.
Post #587695 Sat Sep 28 2019 9:52am
Do any of the electrics on the front passengers seat work? as looking at diagram looks to use same "A" post earth point.
Post #587699 Sat Sep 28 2019 10:05am
Steven 17
Yes I’ve checked the passenger side chair and that all works fine
Post #587700 Sat Sep 28 2019 10:29am
Brit Plumber
I’d now be tempted to refit the original module, check all your connections in the door, clear the fault codes and disconnect the battery for 20 minutes. It could be the BCM has shut down specific circuits and it’s only your door lock are the issue.
If you do go into the door, can you get the engineering part number of the door loom. 2019 5.0 SC SVA (Current)
Post #587702 Sat Sep 28 2019 10:51am
Page 3 of 5 <12345>
