| RRSPORT.CO.UK | ||
|  | Home > General > 2012 sport no power on passenger side |
| Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43      | Dam thing just dosent work | ||
|  Fri Sep 27 2019 9:01pm |
| Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43      | Would the driver side one be different?as I could try swapping them if they are the same | ||
|  Fri Sep 27 2019 9:10pm |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | The drivers side module is different with pt number BH42-14D618-AA.
|  Fri Sep 27 2019 9:30pm |
| Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43      | Ow man made it one digit different just to confuse things ha ha | ||
|  Fri Sep 27 2019 10:03pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Still really puzzling if nothing works on rear door as well, as rear door module on different circuit, fuse 39 and front 30 unless all linked to central locking somehow.
|  Fri Sep 27 2019 10:36pm |
| rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109      | As you measured power going to door module, just throwing these earth diagrams in, not sure they are 100% the same on a 2012 but bet it's fairly similar.
|  Fri Sep 27 2019 11:18pm |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | It’s a little different for the later cars, all the earths run to the door module and then a larger earth runs to a stud at the base of the A pillar. 2019 5.0 SC SVA (Current)
|  Sat Sep 28 2019 7:47am |
| Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43      | I’ll have a go with the multi meter today if I get chance.are all black wires ground or will some be power too? | ||
|  Sat Sep 28 2019 8:03am |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | I think some black are power. 2019 5.0 SC SVA (Current)
|  Sat Sep 28 2019 8:22am |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | Did you say if your speakers are working on the doors?
|  Sat Sep 28 2019 8:23am |
| Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43      | Well when I purchased the car everything was working apart from the door locks on passenger side.when I noticed the door locks wasn’t working a couple of days later I stripped the passenger front lock out to take a look at it.i took the cover off to reveal just 2 motors in the lock.i took the motors out to see if I could find a part number then re fitted them.i put the lock back in as I couldn’t get a replacement the same day.put everything back together and it all worked again apart from the locks on passenger front and back.i purchased new locks for front and rear but before getting chance to fit them I noticed nothing was working then.so I did a google search and it came up with a blown door module so I ordered a direct replacement.when it arrived I plugged it in and I got power to the windows on their own switches on the door but nothing would work from the main switch on the drivers side then after like a minute or two they would stop working.since removing the original module thow I’ve not had the power mirrors work at all.ive fitted new locks to both doors but they won’t lock either.ilve not chef to see if I’m getting sound from the speakers I’ll check that later on and let you know. | ||
|  Sat Sep 28 2019 8:52am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Do any of the electrics on the front passengers seat work? as looking at diagram looks to use same "A" post earth point.
|  Sat Sep 28 2019 9:05am |
| Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43      | Yes I’ve checked the passenger side chair and that all works fine | ||
|  Sat Sep 28 2019 9:29am |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | I’d now be tempted to refit the original module, check all your connections in the door, clear the fault codes and disconnect the battery for 20 minutes. It could be the BCM has shut down specific circuits and it’s only your door lock are the issue.
|  Sat Sep 28 2019 9:51am |
| Posting Rules
