Home > General > 2012 sport no power on passenger side
Page 2 of 5 <12345>
Brit Plumber
I’ll dig some diagrams out.
Have you checked the links in the engine fuse box? If you haven’t, check them all but in particular 17E and 18E, both 50 Amp, 17E powers the LH windows amongst other things via the Central Junction Box, it also sends power to the BCM so it probably isn’t that link but worth a check. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587614 Thu Sep 26 2019 12:23pm
Steven 17
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Fuji White
Ok so I’ve checked with a multi meter the reading I’m getting from the power to ground is 8.57 volt.i tried the ground part of indicator to the ground on car and got continuity.ive pulled fuse 17 and 18 out and they are fine and working
Post #587619 Thu Sep 26 2019 3:40pm
Brit Plumber
Well that’s quite odd, to get almost 9v, and have continuity to earth but not work....
Did the 8.57 volt fluctuate from 0 to 8.57v and back to 0 or constant? 2019 5.0 SC SVA (Current)
Post #587629 Thu Sep 26 2019 4:47pm
Steven 17
I thought that but the thought it may have to be 12v.it didn’t fluctuate it stayed at 8.57.im going to pull the driver side indicator out tmoz and see what voltage I get there.ow and I did check the bulb was good ha ha.yes and solid continuity through the ground, dam car
Post #587635 Thu Sep 26 2019 6:24pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Water leaking onto CJB wouldn't be fun, but as far as I can see, everything not working goes into the same plug on CJB.
Hopefully it's less sinister Embarassed
https://www.rrsport.co.uk/gallery/albums/u...ssrev1.pdf
Get everything dried out and find the leak/leaks, could be in more than 1 location, sunroof/drains/scuttle panel etc.
A dehumidifier works well
Good luck
Post #587645 Thu Sep 26 2019 11:00pm
Steven 17
I really do hope it’s not that.ive actually taken that out and physically examined it and couldn’t find any signs of water or any damage what so ever.i so hope it isn’t that to be fair
Post #587649 Fri Sep 27 2019 6:29am
What voltage? if any have you got on the yellow and red wire here at this connection, as that wire appears to be battery supply to at least the n/s front door module from the CJB connector C0586R.
Post #587650 Fri Sep 27 2019 7:14am
Steven 17
Thanks mate I’ll give that a try.looking at that picture I’m guessing that is the main connection from the car to the door loom?ill do my best to get to it later.its a bit of a pain to get to
Post #587652 Fri Sep 27 2019 8:39am
Steven 17
Ok so I’ve found the yellow/red wire going to the door loom.put the multimeter on and I’m getting 11.96 volt going into the door.surely that is a good sign.so what could I possibly try now?any ideas welcome
Post #587657 Fri Sep 27 2019 12:40pm
Brit Plumber
If you have power there then I suppose the next logical step is to test that wire at the door module.
This is a really odd fault but going back to the door module, you say you replaced it with like for like, can you remember the engineering part number of it? 2019 5.0 SC SVA (Current)
Post #587664 Fri Sep 27 2019 4:28pm
Steven 17
I will check that next as the heavens opened as I was messing so had to give up.as soon as I’m home I’ll get the original one back out and the part fitted and give you the numbers.see if you can make any sense of it ha ha
Post #587665 Fri Sep 27 2019 5:45pm
Steven 17
Yes I just replaced it with the exact same part number which is BH42 14D617 AA
the number under that is 10020648 02
Sw:14C108 AA HW:14C237 AA
Post #587669 Fri Sep 27 2019 8:29pm
Steven 17
Took a pic of the original
Post #587670 Fri Sep 27 2019 8:30pm
Steven 17
It should upload this time ha ha
Post #587672 Fri Sep 27 2019 8:32pm
Steven 17
Post #587673 Fri Sep 27 2019 8:33pm
Page 2 of 5 <12345>
