Home > Technical > Suspension & Starting Issue
drb1709
I lowered and locked my 2010 year car to change the front brake pads. By the way, I am trying Hawk ceramic ones as since fitting a pair of 6 pot Brembos, I couldn't stop brake squeal from the LR/Brembo/Pagid pads.
Anyway, when I had finished, I couldn't start the engine or raise the suspension.
The suspension height control was showing the suspension was locked, in access height, and the normal running height line was also lit. The latter wasn't lit when I initially locked it down.
After half a dozen or so attempts, it did start and I was able to raise the car no problem.
My concern is that there is a problem that may be in the making.
Any ideas of the potential issues if left?
Much appreciated.
Dave
Post #586807 Thu Sep 12 2019 5:11pm
Bardley
After jacking, the car can take a while to makes its mind up about heights and levels.
Usual practice is to just jack up as per any other car rather than start messing with the height. It's not necessary with a D4 either.
I've had to lift and lower again with a jack to get the suspension to pick itself up. Not really a fault, just a user introduced glitch... 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #586835 Thu Sep 12 2019 10:22pm
Not sure about the suspension, but the only thing that shut my S/C Brembo's up were EBC Redstuff brake pads.
Post #586838 Thu Sep 12 2019 10:32pm
Brit Plumber
Raise and lower the vehicle while moving to reduce the strain on the suspension as it changes geometry. In regards to the engine not starting after lowering, I’ve never experienced that but it could be something to do with your brake pedal switch seeing as you’d just replaced the brake pads. Had you pumped the brakes to bed the pads down? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #586854 Fri Sep 13 2019 6:49am
drb1709
Gents,
Bardley - Thanks, it makes sense and will follow your advice in future.
Col - I did a search and was considering Red Stuff when I came across the Hawks, but will remember next time, thanks.
Brit Plumber - No I had not pumped the brakes before trying to start the engine, that's a very good point, thanks.
When I need to go there again I will bear these suggestions in mind, really appreciate your time.
Dave
Post #586860 Fri Sep 13 2019 7:58am
Brit Plumber
I can second Cols recommendation for Red Stuff, I followed his advice on another thread and although I never had a permanent squeal (very occasionally) the red stuff gives off a lot less dust to clean off the wheels...and I hate cleaning wheels!! 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #586861 Fri Sep 13 2019 8:10am
