![]() | Home > Maintenance & Modifications > rear L/H seized caliper |
New calliper is best option,yes you can get a tool to clamp the pipe or use some mole grips but put a piece of cloth inbetween grips & pipe so not to damage pipe the once new calliper is fitted slacken bleed nipple remove grips & then the calliper will gravity bleed,once only fluid is coming out re tighten nipple & all done. Andy.
GerryG Member Since: 07 Jul 2019 Location: Coatbridge Posts: 27 ![]() ![]() |
Great was going to go with the new caliper, do you think changing both is a good idea or just the one.
I myself would change both as they will probably be same age & also replace with new discs & pads,that way they are all new & check & clean hand brake mechanism while you have discs off. Andy.
Yea changed the discs and pads yesterday, that when I found the seized caliper, the rubber boot has disintegrated completely |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
A new caliper is sub £50. Its not worth rebuilding |
Wow! I didn't realise they were that cheap Mike. Kev
Can be found even cheaper. It actually costs more in labour to free off a caliper than it does to replace the thing |
Go one from LR Parts for £38 quid |
