| RRSPORT.CO.UK | ||
|  | Home > Technical > Changing battery |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | Just make sure the ignition is off and then disconnect the negative terminal. That'll be fine. Kev
|  Wed Jun 26 2019 4:07am |
| N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32    | turn ignition off, wait 10 min. then disconnect. RR 2012 4.4 TDV8 | ||
|  Wed Jun 26 2019 6:52am |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | My car has a label next to the battery which I think shows IGN off, wait 2 minutes to power down, then remove neg battery clamp. Ignore my pointer, the photo was for another chap.
|  Wed Jun 26 2019 8:17am |
| DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264      | Hi guys
|  Fri Aug 09 2019 8:23pm |
| Ljdiscovery Member Since: 30 Apr 2016 Location: La Jolla, california Posts: 42      | You only need to connect the vent tube if you have a vented battery. Some are sealed. Phil | ||
|  Sat Aug 10 2019 12:39am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143      | It’s more important when batteries are in the boot.
|  Sat Aug 10 2019 8:08am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | Remember to reset the BMS, plus the battery should be an AGM battery, loads of info on here and the Disco Forum...Fussy animals these cars In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
|  Sat Aug 10 2019 8:13am |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | Why AGM? My original LR battery wasn’t. 2019 5.0 SC SVA (Current)
|  Sat Aug 10 2019 8:32am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | Both my sports came with an AGM battery as standard In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
|  Sat Aug 10 2019 8:35am |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | We’re they L320s? 2019 5.0 SC SVA (Current)
|  Sat Aug 10 2019 8:46am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | My S/C certainly never came with a AGM as standard, although I have fitted one now.
|  Sat Aug 10 2019 8:48am |
| Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656      | LR AGM here from new, thought all Facelift had them fitted  | ||
|  Sat Aug 10 2019 9:15am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | As normal L/R confuse things, RRS1 Petrol Variants only ever had wet cell batteries fitted, 3.0 and 3.6 up to VIN No. BA716316 had wet batteries, BA716317 on had AGM's fitted.
|  Sat Aug 10 2019 9:39am |
| DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264      | Thanks for all the replies guys   | ||
|  Sat Aug 10 2019 9:17pm |
| Posting Rules
