Home > Technical > Changing battery
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Changing battery
I need to disconnect my battery for a minute or 2 in order to replace the 60A glow plug fuse.
My concern is to know if there is a particular procedure to follow and more important will it upset any settings etc on the vehicle when I reconnect?
I assume it is safe to disconnect just the negative.
Any help would be much appreciated. RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #583035 Tue Jun 25 2019 10:29pm
knwatkins
Just make sure the ignition is off and then disconnect the negative terminal. That'll be fine. Kev
Post #583038 Wed Jun 26 2019 5:07am
N60613
Bosnia Herzegovina
turn ignition off, wait 10 min. then disconnect. RR 2012 4.4 TDV8
Post #583043 Wed Jun 26 2019 7:52am
Brit Plumber
My car has a label next to the battery which I think shows IGN off, wait 2 minutes to power down, then remove neg battery clamp. Ignore my pointer, the photo was for another chap.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583052 Wed Jun 26 2019 9:17am
DEVON
Hi guys
Replaced my battery today for a new exide EA 1000
When I removed the old battery, I found what I believe to be the vent pipe tucked underneath it ? And not connected to anything ??? I assume it’s been like that for the 3 1/2 years I’ve owned it Sad
My question is .…. 1. should this be connected to the new battery ?
2. Should the vent pipe have an insert , that connects said pipe to battery ?
Thanks
Devon.
Post #585141 Fri Aug 09 2019 9:23pm
Ljdiscovery
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
You only need to connect the vent tube if you have a vented battery. Some are sealed. Phil
Post #585142 Sat Aug 10 2019 1:39am
It’s more important when batteries are in the boot.
But lr must have fitted it for a reason.
Post #585143 Sat Aug 10 2019 9:08am
SRE
Spain
Remember to reset the BMS, plus the battery should be an AGM battery, loads of info on here and the Disco Forum...Fussy animals these cars In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #585144 Sat Aug 10 2019 9:13am
Brit Plumber
Why AGM? My original LR battery wasn’t. 2019 5.0 SC SVA (Current)
Post #585145 Sat Aug 10 2019 9:32am
SRE
Spain
Both my sports came with an AGM battery as standard In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #585146 Sat Aug 10 2019 9:35am
Brit Plumber
We’re they L320s? 2019 5.0 SC SVA (Current)
Post #585147 Sat Aug 10 2019 9:46am
My S/C certainly never came with a AGM as standard, although I have fitted one now.
Post #585148 Sat Aug 10 2019 9:48am
Buckster
LR AGM here from new, thought all Facelift had them fitted Question 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #585149 Sat Aug 10 2019 10:15am
As normal L/R confuse things, RRS1 Petrol Variants only ever had wet cell batteries fitted, 3.0 and 3.6 up to VIN No. BA716316 had wet batteries, BA716317 on had AGM's fitted.
Post #585150 Sat Aug 10 2019 10:39am
DEVON
Thanks for all the replies guys Thumbs Up
The exide premium EA1000 is a wet battery, and “apparently” an upgrade to the the battery I had ?
My sport was never fitted with an AGM battery , and I’m still non the wiser if the new battery should be vented or not ?
I’ve ordered a vent elbow (as the pipe I found under the old battery doesn’t have one) And I will attach it just in case . I can’t see it doing any harm Whistle
Devon.
Post #585185 Sat Aug 10 2019 10:17pm
