![]() | Home > Technical > Changing battery |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Just make sure the ignition is off and then disconnect the negative terminal. That'll be fine. Kev
| N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32
turn ignition off, wait 10 min. then disconnect. RR 2012 4.4 TDV8 |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
My car has a label next to the battery which I think shows IGN off, wait 2 minutes to power down, then remove neg battery clamp. Ignore my pointer, the photo was for another chap.
| DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264
Hi guys
| Ljdiscovery Member Since: 30 Apr 2016 Location: La Jolla, california Posts: 42
You only need to connect the vent tube if you have a vented battery. Some are sealed. Phil |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
It’s more important when batteries are in the boot.
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Remember to reset the BMS, plus the battery should be an AGM battery, loads of info on here and the Disco Forum...Fussy animals these cars In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Why AGM? My original LR battery wasn’t. 2019 5.0 SC SVA (Current)
Both my sports came with an AGM battery as standard In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
We’re they L320s? 2019 5.0 SC SVA (Current)
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
My S/C certainly never came with a AGM as standard, although I have fitted one now.
| Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656
LR AGM here from new, thought all Facelift had them fitted |
As normal L/R confuse things, RRS1 Petrol Variants only ever had wet cell batteries fitted, 3.0 and 3.6 up to VIN No. BA716316 had wet batteries, BA716317 on had AGM's fitted.
Thanks for all the replies guys |
| All times are GMT |
